jrflying
jrflying New Reader
9/18/11 10:44 a.m.
Just looking for a little troubleshooting help. I have a 2004 Grand Cherokee and the keyless entry isn't working. Also, the only power door lock that works is the front driver's side door and the only power windows that work are the driver's side windows. I have checked for broken wires in both of the buddles at the front doors but there don't appear to be any. Any other ideas of the fix?
bluesideup
bluesideup Reader
9/18/11 1:24 p.m.
Have you used a multi-meter to check for continuity on the black ground wire inside the driver's door harness? Pull the door panel off and check that first.
Ranger50
Ranger50 Dork
9/18/11 1:42 p.m.
Sounds like a BCM problem.....
amiller34
amiller34 New Reader
9/18/11 6:46 p.m.
I've fixed two of these now, the wires to the drivers door break right where it exits the body to the door. It's either the large gauge orange or black wire, windows and locks all run through the drivers door and when the power is severed it all goes wonky. Pull the rubber boot for the door wiring loose at the body, 2 layers to find it. The door wiring will unplug from the door and after some kick panel deconstruction it can be fed into the foot well for repair. Google search found a good tutorial with pics that solved my first one.
uwkAdLYNwhEp0EFqqhqYVbAHThdkktXXutzNauyKIO8wgvciqmYszrTsr1cbb5jW
