aussiesmg
aussiesmg SuperDork
12/26/11 11:12 a.m.
How do I hook up a 24v charger to a 2 x 12v battery, 24v charging system?
Is either positive and negative ok, on alternative batteries, or must they be charged in one particular way?
HappyAndy
HappyAndy HalfDork
12/26/11 11:19 a.m.
The batteries must be connected in series so that in effect the 2 12v batteries have become 1 24v battery. Hook the leads of the charger to the terminals of the 24v battery. Done.
HappyAndy
HappyAndy HalfDork
12/26/11 11:22 a.m.
OTOH why would you be charging with a 24v charger? Does the machine in question operate on 12 or 24 volts?
12/26/11 11:22 a.m.
yes.. positive of one batter to the negative of the other.. then the positive lead of the charge to the free pos and the negative lead to the free neg
aussiesmg
aussiesmg SuperDork
12/26/11 3:19 p.m.
Andy, the machine in question is a 1966 MCI bus with a Detroit diesel, it is 24 volt, but utilizes two 12v batteries wired in sequence. There is no 24 volt battery, hence the question.
There are two options for connection, positive on one to negative on the other, just wondering if it matters which way they are hooked up. Both batteries have a positive and a negative obviously.
12/26/11 4:19 p.m.
yes. Most larger trucks use 2 twelve volt batteries to make 24 volts. Two batteries wired together.. positive to negative will produce 24 volts.
The other alternative is to unhook the batteries from each other and charge them individually
Thing you have to be careful of. Make sure they are really wired in series. I have seen some smaller box trucks with 2 12 volt batteries... but the truck still ran on 12 volts.. it was only using two batteries for starting amperage
aussiesmg
aussiesmg SuperDork
12/26/11 5:39 p.m.
it is 24v
TRoglodyte
TRoglodyte HalfDork
12/26/11 6:17 p.m.
I usually identify where the positive and negative are leaving the battery box and hook to+ & - at that point.
aussiesmg
aussiesmg SuperDork
12/26/11 6:20 p.m.
That's the info I was looking for, thank you.
TRoglodyte
TRoglodyte HalfDork
12/26/11 6:24 p.m.
I haven't blown a battery yet, YMMV . Negative ground? (most likely) . 24 volt charger?
aussiesmg
aussiesmg SuperDork
12/26/11 6:35 p.m.
Yes, getting one over the next week or so, charger and maintainer.
Like this
http://www.ebay.com/itm/330661055679?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1801wt_1037
TRoglodyte
TRoglodyte HalfDork
12/26/11 6:43 p.m.
Looks like a good maintainer unit. got a block heater? Will it be started over the winter? We have used a heated dipstick or a magnetic heater on the oilpan in cold weather.
aussiesmg
aussiesmg SuperDork
12/26/11 6:47 p.m.
No block heater, it would only be started to get the hell out of the snow, probably not going anywhere until the Mitty as of right now though. The magnetic heater sounds neat though.
I have a few projects to do on it yet, like a hitch that has to clear the engine cradle, steering maintenance (maybe a steering box)
TRoglodyte
TRoglodyte HalfDork
12/26/11 6:53 p.m.
May I suggest some anti gel in the fuel Before the weather gets stupid crazy cold?
aussiesmg
aussiesmg SuperDork
12/26/11 6:58 p.m.
Hmmm, is Stabil OK in diesel?
Sorry I am a total newb when it comes to diesels
TRoglodyte
TRoglodyte HalfDork
12/26/11 7:04 p.m.
Cetane boost, best I remember it's a diesel fuel additive. Sta Bil I have no knowledge of in diesel fuel. I could look at a bottle tomorrow.
RexSeven
RexSeven SuperDork
12/26/11 7:05 p.m.
Anti-gel is separate from Sta-bil, although there is a special diesel formulation Sta-bil that's about $20/bottle. You can find anti-gel at any FLAPS and probably any nearby truck stops as well.
Don49
Don49 Reader
12/26/11 7:06 p.m.
Go to your local Wally World and get Kleen Diesel fuel conditioner.
aussiesmg
aussiesmg SuperDork
12/26/11 7:06 p.m.
I will get something tomorrow either way
curtis73
curtis73 GRM+ Memberand Dork
12/26/11 11:05 p.m.
There are a couple ways to charge. Like has been said, you can disconnect the jumper between the batteries and charge each on individually with a 12v charger. You can get a 24v charger and hook them up positive to the positive post (the one that goes out to the starter) and negative to the negative (the one that goes out to ground).
You can also get a marine 12v charger that charges two banks and hook each negative to each negative, and each positive to each positive. They have discreet outputs (not linked together) so that you aren't shorting anything and it will charge each battery separately treating them as two individual 12v batteries.
12/27/11 12:32 a.m.
kerosine can also work in a pinch to keep diesel from gelling.
I would look around for a block heater.. I bet it already has one
aussiesmg
aussiesmg SuperDork
12/27/11 5:07 a.m.
Good idea it did serve in Illinois as a CCNO vehicle
thanks Curtis that might be a good option, I didnt know about those chargers
wclark
wclark New Reader
12/27/11 6:31 a.m.
For wet cell battery maintenance I love Battery Tender brand by Deltran. I have 3 of the 12V Battery Tender Plus models at home - 2 are in constant use. One for a car that is mostly stored but gets driven a a moments notice, one for the tractor that only gets used for snow removal and occasional maintenance around the place and a third that moves back and forth to keep the generator and lawn mower batteries charged.
They do sell 2 and 4 bank models but I found I could buy 2 single bank charges for less than the price of one 2 bank model and since the car, tractor, and the generator and lawnmower are stored over 100' apart in three separate buildings a multibank would not have worked or me anyway.
2c5nuaZPg8olAsmsQulcujAWpRkDtJltff2ztEhJypZiZcyDbIJSficBSGKLI4jp
