NOHOME
NOHOME PowerDork
2/10/16 10:31 a.m.
Getting rear tires on the back of the Molvo is right on the edge. With zero Camber, I have 1/2" interference. The optins are wheels with more offset, fender flares, or camber increase.
If I dial in some camber, I might get this to the point where the tires will tuck under with just a fender lip roll.
I do not want to go all stanceworks with this nor make the car handle weird. So what is a reasonable negative camper number for a street driven Miata or should I just stick with stock and work it out with bodywork?
Also, not seeing much negative camber with the stock a-arms. what should I expect to be able to achieve?
2/10/16 10:34 a.m.
Depends on how lively you want the rear end to be...-2deg is no big deal. Anything under -3deg isn't crazy.
NickD HalfDork
2/10/16 10:37 a.m.
I run -2deg all the way around and 0deg of toe. The camber is particularly visible in the rear but it doesn't look all janky.
2/10/16 11:28 a.m.
Yup, visible rear camber is totally normal. Street cars have been running about 1.5 negative rear camber for the past two decades.
NOHOME
NOHOME PowerDork
2/10/16 11:44 a.m.
OK, then I will put "Up to -2 degrees" in the arsenal towards getting the rear tires under the fenders.
This thing is gonna be Hella-flush no matter what!
BrokenYugo
BrokenYugo UltimaDork
2/10/16 4:31 p.m.
Using trigonometry, it would appear that -2 degrees gives you 0.9" with a 26" tire.
EDIT: That number only works on a spherical Miata in a vacuum.
2/10/16 7:21 p.m.
The adjusters are on the lower control arm, so it pivots around the upper. Just in case that comes into your trig :)
rslifkin
rslifkin Reader
2/10/16 7:23 p.m.
Keith Tanner wrote: The adjusters are on the lower control arm, so it pivots around the upper. Just in case that comes into your trig :)
That matters a lot, as it'll be pushing the bottom of the tire out more than it pulls the top in.
NOHOME
NOHOME PowerDork
2/10/16 7:30 p.m.
The fact that the camber was dialed in from the bottom was a concern.
So, maybe something like this is in my future. (Or one of the variations on the market)
2/10/16 7:45 p.m.
Better option, really lets you tuck the top of that wheel if necessary :)
https://www.flyinmiata.com/rear-upper-control-arms.html
2/10/16 8:47 p.m.
I prayed it wasn't about this:
hAydSXyynBekUKaBtYzm2XegJi9OKnx45EiWK2hDmzaJaBkJfBxSyjrT5JStHRt9
