pirate
pirate Reader
1/19/16 8:32 p.m.
Can anyone recommend a decent quality air tank? What size works best for just topping off tires or adjusting pressure. Aluminum or steel? Can pressure be adjusted?
Kenny_McCormic
Kenny_McCormic UltimaDork
1/19/16 9:19 p.m.
I suppose you could put a air compressor regulator on one. I have one made from a old 20lb propane tank (flood with water to get ALL the propane out) and old junk laying around, works fine for topping off tires.
oldopelguy
oldopelguy UltraDork
1/19/16 9:23 p.m.
My dad put a fill valve, relief valve, gauge and air chuck on a 100# propane tank and strapped it into a jogging stroller frame. For taking to the track it's not so great, but for flat tires around the farm it's awesome.
1/19/16 9:29 p.m.
I have an old 40gal aircompressor tank from a cheap husky compressor. The motor died, but the tank works great
44Dwarf
44Dwarf UltraDork
1/20/16 6:59 a.m.
Jegs sell a nice alum 5 gall one. I have two steel ones but they never get used now.
Brian
Brian MegaDork
1/20/16 7:05 a.m.
How would one go about converting old propane tanks? I have several 20# and a 40# that have the old "no external thread" valves.
JeremyB
JeremyB New Reader
1/20/16 7:39 a.m.
Brian wrote: How would one go about converting old propane tanks? I have several 20# and a 40# that have the old "no external thread" valves.
Find an old grill regulator that fits your tank. Take the pipe off the regulator and it will have 1/4" npt threads on the end. You'll also see that it has a small hole for the propane to go through. Drill this out and then replace the regulator with an air chuck. It works great.
pirate
pirate Reader
1/20/16 7:39 p.m.
It occurred to me after doing some looking on Jegs and Summit Racing that possible one of the 12 volt compressors may be a better solution then an air tank for topping of tires and adjusting pressure. Has anyone used or can recommend a quality 12 volt compressor. not talking about the elcheapo ones for 10 or 12 dollars.
Brokeback
Brokeback Reader
1/20/16 7:48 p.m.
I have one of these for offroading trips, works great (although not super fast on 33s) so far. I've had it for 3 years, I probably use it 10 times/year maybe? But when I do use it I'm inflating 4 33x10.50 tires from 15 PSI to 35 PSI.
http://www.amazon.com/VIAIR-85P-Portable-Air-Compressor/dp/B0036E9VB6/ref=pd_sim_263_4?ie=UTF8&dpID=41mVgGPDU5L&dpSrc=sims&preST=AC_UL160_SR160%2C160&refRID=1HC65K7WKT5VMSEEQHYP
rslifkin
rslifkin Reader
1/20/16 7:54 p.m.
Viair makes solid units. I've heard lots of good things about the Puma units you can find on Ebay (and I think a couple of other places online). They push some pretty good air too (3 cfm @ 90 psi for the big one, IIRC) but they do draw a good bit of power to do it.
hfPel4orKACAYqBF54NJrPPaoZ2zBGTv0ECOT48KhDtveKXR7OCYzpWF6zT5I99o
