JamesMcD
JamesMcD Reader
2/10/13 6:47 p.m.
I am putting a KL series Mazda V6 into one of these:
('86 626 Coupe GT)
I'm not worried about the mechanical bits, but because I am a nerd, I desire that the car retain it's goofy 80's digital gauge cluster:
There are aftermarket solutions for tweaking the tach signal, to account for the extra cylinders, so I am not worried about that...
My issue is that although the recipient car and the KL-powered cars share the same transmission innards, the KL cars use a speedometer sensor while the '86 626 uses a speedometer cable. The '86 626 speedometer cable doesn't go into the KL transmission's speedometer sensor hole, either.
Sooo...
Here is a chunk that I liberated from the insides of my digital cluster:
The speedo cable goes into the back and drives a wheel for a hall-effect sensor. You can see the odometer drive on the far side (that's a different issue.) Here's shot of both sides of the board that the hall effect sensor is on. I mirrored the right side so it's easier to see what is going on:
This board sends a signal that gets interpolated into digital numerals, elsewhere in the cluster. If I were to guess, I would think that this board just keeps the voltage pulse that comes from the hall effect sensor inside of a range that can be used by the circuit that decides what digital numerals to display. I see there are a couple resistors and a capacitor there (the bulb portion at the top is obvious and not a concern). But that's about all I know.
With all that said, what I want to do is, create a circuit that takes input from the speedo sensor on the transmission, and outputs an appropriate signal into the board above, or the OUT lead on the board above, making the cluster think that there is still a speedometer cable spinning the hall effect wheel.
I am not asking for a step-by-step on how to do this.
I am just wondering if anyone can point me to some book, forum, website, or other resource which can teach me just enough about the subject at hand to accomplish this.
Is this something that Arduino can do?
Thanks
psychic_mechanic
psychic_mechanic Dork
2/11/13 9:30 a.m.
I would think it would be simpler to take the electrical impulse from the trans and use it (through a controller and motor) to spin an actual speedometer cable. This way your odometer will actually work too. Considering the number of old muscle cars that have newer engines swapped in, there is probably an off the shelf solution or documentation of how to make your own in a project box.
JamesMcD
JamesMcD Reader
2/11/13 10:07 a.m.
I thought about that as well, but was unable to find anything. All the aftermarket geegaws seem to be for converting in the opposite direction.
bradyzq
bradyzq Dork
2/11/13 11:50 a.m.
Do you know what the output of the KL speed sensor is? It may very well be the same as what the Hall sensor sees in the '88 626 cluster. In which case it would be a simple case of removing the Hall sensor in the cluster and soldering in the wires from the KL speed sensor.
The odo, on the other hand......
GameboyRMH GRM+ Memberand UltimaDork
2/11/13 11:54 a.m.
Yeah you could custom-build something to spin a motor so your odometer would work...but for that amount of trouble, you'd be better off building a digital odometer.
Swank Force One
Swank Force One MegaDork
2/11/13 12:01 p.m.
Hey James,
17-441 to 17-442 assembly is what i was talking about.
91-96 Escort GT/LX-E
91-94 Protege LX. 91-96 Tracer LT-S.
Multiple threads on ClubProtege showing people successfully installing those into an MX3 trans, so it'll work in Probe/MX6 as well, same case.
The only question from there is will the cable match up to your existing GC stuff.
VSVITdeiRQriG7nP9XMUWokKksnoQ80vh7czCfayPyf13AMtaoCOR88esQAgQFNL
