tr8todd
tr8todd New Reader
5/26/10 7:49 p.m.
I'm nearly finished sanding off two layers of paint on the TR8 bringing it back to bare metal. All that is left is the dreaded hood. Anybody have any tips for sanding in between louvers? The TR8 hood has a set on either side of the hood, and it takes forever trying to get in between the slats with folded up sand paper. I don't want to use chemical stripper because it messes up the back side of the hood, creating even more work.
angusmf
angusmf Reader
5/26/10 7:57 p.m.
I don't know the best way, but I'd avoid sandblasting. I had a hood sandblasted and it warped the hell out of it.
pigeon
pigeon HalfDork
5/26/10 8:00 p.m.
Is the gap big enough to fit one of those little handheld "mouse" sanders in? Other than that, grab a beer or three, sandpaper and a strong thin sanding block, some good tunes and get to it.
Junkyard_Dog
Junkyard_Dog HalfDork
5/26/10 8:23 p.m.
Say goodbye to your fingerprints +1 on adding beer. Take your time and don't rush or the last one will look way worse than the first.
924guy
924guy Dork
5/26/10 9:18 p.m.
popsicle stick + sand paper, repeat as necessary. by the time your done, youll be able to core an apple with your finger tips... Mr Myiagi will be proud.
triumph5
triumph5 New Reader
5/26/10 9:21 p.m.
Sand paper wrapped around an electric toothbrush??
triumph5
triumph5 New Reader
5/26/10 9:44 p.m.
In reply to racinginc215:
I see a shiny carb in my near future..
5/26/10 10:33 p.m.
baking soda is the E36 M3.... works great and nothing left behind
Woody
5/27/10 6:49 a.m.
note to self:
...Buy old vehicle with crusty carbs...
Ian_F
Ian_F Reader
5/27/10 7:34 a.m.
racinginc215 wrote: don't laugh it works. here
I need one of those.
Funny how the Eastwood catalog specifically says NOT to use standard household baking soda... bastards...
triumph7
triumph7 Reader
5/27/10 8:36 a.m.
Why not use a wire wheel?
John Brown
5/27/10 8:37 a.m.
Standard household baking soda will screw with real soda blasters, if you notice there is no orifice nozzle on the homebrew kit. Arm and Hammer will collect moisture and "grow", clogging the orifice.
Ian_F
Ian_F Reader
5/27/10 12:00 p.m.
Ah... good to know...
Karl La Follette
Karl La Follette HalfDork
5/27/10 12:32 p.m.
use dawn power dissolver spray on then cover with garbage bag leave overnight then pressure wash off paint $2-75 bottle works wonders
Appleseed SuperDork
5/28/10 12:56 a.m.
Why not hit it with aircraft paint stripper?
digdug18
digdug18 HalfDork
5/28/10 9:28 p.m.
Micromark to the rescue. at $70 mind you...
Andrew
Marjorie Suddard
Marjorie Suddard General Manager
5/29/10 8:25 a.m.
One warning about the soda blaster: If you use it outside, know that the media will kill your grass. Quite efficiently.
I have read that washing the area afterward will help, and adding vinegar to the wash should go a long way to correcting the problem by lowering the pH back to what the grass can tolerate. But of course, to do that, it helps to know that someone was in the back yard spewing soda all over the place--before you look and say, "Hey, where'd all the grass go?"
Margie
motomoron
motomoron Reader
5/29/10 3:12 p.m.
If you use aircraft stripper and ~work carefully~ you can get most of it without getting the backside. Use 1" chip brushes to apply, scrape the bubbled up old paint w/ plastic scrapers, hose off to neutralize the what gets on the inside. Also, you can apply grease as a resist on the inside of the hood.
I'd rather catheterize myself w/ hot welding rod than mechanically strip a hood covered in louvers.
motomoron
motomoron Reader
5/29/10 3:14 p.m.
Oh - one more idea:
3M stripping wheels. They get in there pretty good and obviously only get what you're gettin' at.
FbMN0FTqhRvFa1rNylnj7Q29BCzNFyOcUuuss5o46keH0mXYLl5RgHMHc1VuOLmM
