93EXCivic
93EXCivic SuperDork
7/28/11 11:34 p.m.
Ok so I was thinking of using motorbike shocks on the Spitfire but the rear has the leaf spring. Is there any reason I can't remove the coil spring and just run the shock on the rear?
triumph5
triumph5 SuperDork
7/28/11 11:45 p.m.
Structural integrity of the upper mount. It would become a now now-overloaded upper shock mount.
erohslc
erohslc Reader
7/29/11 12:18 a.m.
The Spitfire upper mount is plenty strong enough (hint: transient shock loads far exceed spring loads) Lots of folks have gone to coilovers. ISTR that the Abomination used MC coilovers, and there have been a couple of threads on MC coilovers too.
Carter
bravenrace
bravenrace SuperDork
7/29/11 5:58 a.m.
But aren't you asking about removing the spring on the shock and just using it as a shock along with the leaf spring? That wouldn't be a coil over and I can't see how it could possibly make the shock mount loading any different, except for a change in the stiffness of the shock itself. Or am I misunderstanding the question?
7/29/11 6:42 a.m.
isn't the transverse leaf spring on the spit MORE than just a spring? I thought it was also a locating member of the suspension
pres589
pres589 Dork
7/29/11 6:49 a.m.
Yeah I thought the transverse spring was also an upper locating link on that car.
foxtrapper
foxtrapper SuperDork
7/29/11 6:51 a.m.
Yes, you can run just the shock.
93EXCivic
93EXCivic SuperDork
7/29/11 7:16 a.m.
bravenrace wrote: But aren't you asking about removing the spring on the shock and just using it as a shock along with the leaf spring? That wouldn't be a coil over and I can't see how it could possibly make the shock mount loading any different, except for a change in the stiffness of the shock itself.
Yup that is what I am asking. I am just getting an idiot check to make sure MC shocks don't have anything weird going on.
GregW
GregW New Reader
7/29/11 10:44 a.m.
The motorbike shock is probably too soft to damp the much higher spring rate and greater mass of the spitfire hub and wheel adaquately. I would find a set of adjustable Koni NOS shocks and go from there.
Teh E36 M3
Teh E36 M3 HalfDork
7/29/11 1:24 p.m.
The YZF-R1 shocks have to control a ~500lb/in spring. That should be plenty stiff, right?
triumphcorvair
triumphcorvair New Reader
7/29/11 2:48 p.m.
Just to make sure and reconfirm I'm right, I checked the rear suspension on my 67 MkIII and it doesn't have a "coil over spring" on the shock. PRI makes a rear suspension kit that does away with the transverse leap spring and adds coil overs.
NWUU48UJMmNpSkvtPQxNkX0MSsRlDESB1teiUBOcdGv1pcLWtzH1H8wUleNN6IPf
