stuart in mn
stuart in mn MegaDork
10/23/23 8:36 a.m.
When it comes down to it, a bicycle may be the best vehicle.  No fuel required, easy to repair.
Mike924
Mike924 HalfDork
10/23/23 9:08 a.m.
I have done a quick scan of what everyone has come up with.  The one car or type of car I have not seen listed is the early 1980's Mercedes and VW Turbo Diesels.  Those things run on anything and can put up with a ton of abuse.  Give me a 300TD and I can run it anywhere on anything.  Plus if there is an old McDonalds in the way I can get the French Fry Grease and make everyone that is not a  Zombie hungry!!! LOL
z31maniac
z31maniac MegaDork
10/23/23 9:56 a.m.
Appleseed said:
In reply to A 401 CJ :
Depends on what type of zombie you like. The ones in 28 Days Later were olympic athletes.
10/23/23 10:22 a.m.
A 401 CJ said:
Duke said:
A John Deere tractor from 1945-1965 or so is about as simple as it gets, mechanically, and will run forever. No electronics. It will handle gasoline, kerosene, fuel oil, or propane with a flick of the ignition selector.
It will climb anything in low range and will cruise at 30-35 mph in high range.
Had a '56 and a '57.  Both 420's.  12 mph top speed.
We had a late-'50s Model 40.  It would definitely move faster than 12 mph, even towing.  Not as fast OTR as a Farmall, but faster than you could sprint.
NOHOME
NOHOME MegaDork
10/23/23 10:58 a.m.
4 cylinder gas or diesel.  Perhaps wood fired steam if we are really out of fuel supply of any kind.
In block cam
NOT EFI.
Stick front and rear axles
3 speed gearbox
If you can start it with a crank handle even better cause batteries are going to be hard to come by in Zombie-World.
Carry two passengers inside and cargo area for stuff or more people
Pretty much takes me back to a 1940 or 50s pickup. Assuming that blacksmith technology still exist, they would be repairable and could  run on poor fuel or ethanol.
Whenever I think of this scenario, tires become the big obstacle. They require a pretty extended supply chain of materials and infrastructure to build even one tire.
The Model T is also not a bad choice because if you must go back and start from the beginning, the Ford Model T WAS pretty much the beginning;so start with something proven.
californiamilleghia
californiamilleghia UberDork
10/23/23 11:13 a.m.
Top gear would say a Toyota pickup.....
probably not a bad choice for most of the world ,
SV reX
SV reX MegaDork
10/23/23 11:24 a.m.
Brett_Murphy (Agent of Chaos)
10/23/23 11:35 a.m.
A dual sport motorcycle might work well. You don't need roads, just kind of rough trails and the gas mileage is very good.
Ian F (Forum Supporter)
10/23/23 11:42 a.m.
I used to know a guy who loved guys who ran M-B diesels on veggie oil.  The repair bills put his kids through college.  Yes, they will run on veggie oil, but the injection pumps don't like it long-term.
In theory, the 7.3 IDI in my E350 should be reliable ... once the previous owner's aftermarket alarm system that berks it is removed.  My long term plan is a Cummins 12V as I'd like to be able to measure 0-60 times with a stopwatch instead of a sun dial...
wearymicrobe
wearymicrobe PowerDork
10/23/23 11:49 a.m.
Kawasaki KLR 600 - The Best KLR? - Bare Bones Motorcycles
This is actually unkillable and likely would run on crappy fuel for much longer then anything on the road.
MadScientistMatt
MadScientistMatt UltimaDork
10/23/23 12:47 p.m.
This. No telling how long it would take to restore oil production and fuel distribution, so I would pick an option that won't need that infrastructure.
10/23/23 1:04 p.m.
The best vehicle is whatever your neighbors used to have.
In a true apocalyptic scenario, there will be a lot of vehicles that no longer have owners.  So the end result is whatever still runs that you have the keys for/can hotwire.
3vUYs8kkDhegidLMStNLTJhZ4K7CyBhVrBdaeXVVnfbZbt9RhDggVjbWvcoiUx7r
