TyreReviews
TyreReviews New Reader
1/2/24 2:10 p.m.
Hey All,
Happy new year.
I have a quick question, I recently bought the Turner F80 discs for my track car. The fronts are what I expected, and look very clearly fully floating, but the rears have the hats bolted directly to the rotor and doesn't look like it could even be called a semi floating disc.
Here's some pictures of both the fronts and the rears, including both sides of the rears
https://photos.app.goo.gl/FR79MEYvPpu8mzSdA
Any thoughts would be greatly welcomed.
iansane
iansane GRM+ Memberand Dork
1/2/24 2:23 p.m.
I know it says full floating in the description but in the 'kit contents' section it calls out the fronts as floating and the rears as just 2pc. Which doesn't inherently mean floating.
cyow5
cyow5 Reader
1/2/24 2:44 p.m.
Doesn't "floating" mean they *must* be free to translate axially? Both of those look like they cannot float in any direction unless the fronts are free to translate to the inside which isn't shown. The fronts might translate radially with thermal expansion, but that isn't typically what is meant by "floating"
TyreReviews
1/2/24 4:55 p.m.
In reply to iansane :
https://www.turnermotorsport.com/p-1423068-turner-motorsport-front-and-rear-full-floating-slotted-tracksport-rotors-set-f8x/
I see your point, but right above it is says:
 Turner Motorsport F8x TrackSport Rotors:
  • Turner Motorsport TrackSport Full Floating Slotted Rotor - Front Right
  • Turner Motorsport TrackSport Full Floating Slotted Rotor - Front Left
  • Turner Motorsport TrackSport Full Floating Slotted Rotor - Rear Right
  • Turner Motorsport TrackSport Full Floating Slotted Rotor - Rear Left
and the description is
Turner Motorsport Front And Rear Full-Floating Slotted TrackSport Rotors Set - F8x
It's not even an implication the rears will be floating, it's said twice lol.
APEowner
APEowner GRM+ Memberand UltraDork
1/2/24 5:07 p.m.
Those fronts look like semi-floating and the rears appear to be just two piece rotors.
CAinCA
CAinCA GRM+ Memberand Dork
1/2/24 5:08 p.m.
Looking at the pictures of the backside (#13) it appears that they have a block/spacer that passes through a slot in the the rotor.  Then there's a spring clip on the inside that covers up the slot so you can't see it.
TyreReviews
1/2/24 11:00 p.m.
In reply to CAinCA :
Agreed, that's the front disc (#13) and having handled them my uneducated opinion is that they're floating.
The rears however have thrown me. It's an expensive disc, and not as light as the girodisc or 034 options.
TyreReviews
1/2/24 11:01 p.m.
I guess the saving grace is the fact the rears won't generate nearly the heat of the fronts, and a heavier disc has more capacity for heat.
NnxTVs9OEyzNgQXBuVttOUKhJL9vSObYAFNCqSdB03YxC1hKDhdLkJxXDKZZ2eGq
