z31maniac
z31maniac UltimaDork
10/7/14 11:31 a.m.
Yes, I'm back on a BRZ kick.
I've finally accepted I'm not going to spend $2800+ on a hardtop and Blackbird roll bar for the NC Miata, and the other options are either not what I'd consider safe enough for track work, or a convenience hassle I don't want.
Since it's likely the wife and I will be moving to Dallas next year, I suspect I will spend more time in parking lots then at race tracks since we won't have a tow vehicle.
What are the best classes for the BRZ so I can read up on the rulebook?
captdownshift
captdownshift GRM+ Memberand Dork
10/7/14 11:42 a.m.
SR, PR, MR
cmcgregor
cmcgregor New Reader
10/7/14 11:47 a.m.
autox?
They're pretty dominant in STX(street touring), full exhaust and a tune will get you a pretty decent amount of HP.
Also fairly competitive in CS (street), though there the torque dip will hurt you a lot more. The prep is quite a bit cheaper though.
I don't think anyone has done a full CSP build that I'm aware of, but that's more or less spec miata anyway.
z31maniac
10/7/14 12:07 p.m.
cmcgregor wrote: autox? They're pretty dominant in STX(street touring), full exhaust and a tune will get you a pretty decent amount of HP. Also fairly competitive in CS (street), though there the torque dip will hurt you a lot more. The prep is quite a bit cheaper though. I don't think anyone has done a full CSP build that I'm aware of, but that's more or less spec miata anyway.
Excellent, thank you sir!
cmcgregor
10/7/14 12:13 p.m.
Probably even more competitive in street next year, since the 370Z will be in BS. So the main competition there is the RX-8 and the NC Miata. We have a pretty decent showing of FRS/BRZ up here in both STX and CS (and a few in SM with superchargers) so it's a fun class. They have a pretty amazing amount of grip with just a tire upgrade too. Unfortunately you're pretty camber limited in street, I think the best I got was around -1.25 in the front. Going to STX allows camber plates.
DaveEstey
DaveEstey PowerDork
10/7/14 12:18 p.m.
z31maniac wrote: Yes, I'm back on a BRZ kick. I've finally accepted I'm not going to spend $2800+ on a hardtop and Blackbird roll bar for the NC Miata, and the other options are either not what I'd consider safe enough for track work, or a convenience hassle I don't want. Since it's likely the wife and I will be moving to Dallas next year, I suspect I will spend more time in parking lots then at race tracks since we won't have a tow vehicle. What are the best classes for the BRZ so I can read up on the rulebook?
Given those facts, I have no clue why you would buy a BRZ. You won't be spending time on a track and will be autocrossing, which means no reason to get rid of the Miata.
icaneat50eggs
icaneat50eggs HalfDork
10/7/14 12:43 p.m.
Why no tracks? I think you are righ near hallet now, but Dallas has tracks too.
z31maniac
10/7/14 12:45 p.m.
I said more time at AutoX, not NO time at the track.
Geeez
kylini
kylini Reader
10/7/14 12:52 p.m.
I'm sure you've seen this, but just in case, Flyin' Miata is having fun designing a reasonable track-legal adjustable roll bar of complicated goodness. http://forum.miata.net/vb/showthread.php?t=554550
If this isn't your cup of tea, you really can't go too wrong with the Twins in CS or STX as mentioned above.
z31maniac
10/7/14 12:57 p.m.
I have, that's why I mentioned the convenience part, it's awesome they are building it, but I wouldn't want to deal with it.
DaveEstey
DaveEstey PowerDork
10/7/14 5:01 p.m.
What about buying a cheap(ish) track/play car instead? Or does this need to be a one-car solution.
z31maniac
10/7/14 7:35 p.m.
DaveEstey wrote: What about buying a cheap(ish) track/play car instead? Or does this need to be a one-car solution.
I already had that, it needs to be a one car solution.
Since it's nearly a done deal we will be moving in ~12 months and likely into an apartment/condo, there will be little wrenching opportunities and such.............and honestly, I don't really want to wrench on something older right now.
The NA got that out of my system for at least a few years.
r79MelzJ0eve1GZYVQ1hDRcBU1BFaZCLQtoQRoXnJe6YaDtuIoMDSR6trQAzsIBb
