belteshazzar
belteshazzar SuperDork
6/24/10 4:39 p.m.
so, my grassroots brethren, who makes the best glasspack style muffler?
I've probably bought 15-20 thrush glasspacks over the years. They're okay, mainly just really cheap, but it seems like the packing blows out and I'm looking for something better than that.
This is for my triton 'vic, to use in place of the catalytic converters. I find that placing a glasspack where a converter was keeps the noise level about the same, for less money, and with no added backpressure.
what say you
patgizz
patgizz GRM+ Memberand SuperDork
6/24/10 4:51 p.m.
the chevelle has some old cherrybombs on it that so far have outlasted the jet hot coating on the headers. i normally use them as resonators before or after the muffler to control sound. the thrush ones seem to rust out quicker here in the rust belt
JFX001
JFX001 Dork
6/24/10 4:58 p.m.
Smitty's used to be the E36M3 for the Rodding crowd for years.
Pseudosport
Pseudosport Reader
6/24/10 5:47 p.m.
I like the Thrush ones over the Cherry Bombs because they are perforated compared to louvered. The louvers decreases the inside diameter and disrupt flow but they are slightly quieter.
zomby woof
zomby woof HalfDork
6/24/10 5:55 p.m.
My Cherry bomb GP's are not louvered, and I've never blown the packing out of one (although my cars don't make a lot of power)
fastmiata
fastmiata Reader
6/24/10 8:23 p.m.
The guys that make Cherry Bombs are located in my town and are so very supportive of racers even to the point of designing my SM exhaust. Buy their stuff please.
AquaHusky
AquaHusky New Reader
6/24/10 10:23 p.m.
I can usually get a 12 inch glasspack from the local shop for like 25 bux. I would think that would be fine as resonators in place of the ''Cadillac Coverters''.
Trans_Maro
Trans_Maro Dork
6/24/10 11:26 p.m.
Smithys for that old-school sound.
They're steel packs so they don't burn out.
The longer they are, the mellower the sound.
Shawn
Opus
Opus Dork
6/25/10 12:49 a.m.
bravenrace
bravenrace Dork
6/25/10 7:33 a.m.
Fiberglass packing will eventually burn out in any muffler. Oh, and if you can afford an engine swap, you can afford cats. Run them.
angusmf
angusmf Reader
6/25/10 8:58 a.m.
bravenrace wrote: Oh, and if you can afford an engine swap, you can afford cats. Run them.
IF your engine isn't blowing a ton of unburned fuel out of the exhaust, such as in a race engine. In that case it's pointless and you'll just melt the matrix. But otherwise I agree that it's nicer to run them.
bravenrace
bravenrace Dork
6/25/10 9:18 a.m.
I'm thinking a relatively stock engine like the one in his car. I'm no tree hugger, but the good that cats do far outweighs any benefit of not having them. Unless they are the four legged kind, and then I have no use for them.
belteshazzar
6/25/10 4:49 p.m.
I do feel a little guilty, but a decent pair is probably $300. $200 more than I intend to pay for glasspacks. That's a meaningful amount of money for something I don't HAVE to buy.
ScottRA21
ScottRA21 Reader
6/25/10 5:16 p.m.
belteshazzar wrote: I do feel a little guilty, but a decent pair is probably $300. $200 more than I intend to pay for glasspacks. That's a meaningful amount of money for something I don't HAVE to buy.
Well, do Burns Stainless count as glasspacks? They might be expensive, but you probably would only need to buy them once. Ever. And they weigh next to nothing as a side benefit.
zomby woof
zomby woof HalfDork
6/26/10 5:56 a.m.
If you're talking about cats, you can buy them for about $60 a piece.
njansenv
njansenv HalfDork
6/26/10 1:21 p.m.
belteshazzar wrote: so, my grassroots brethren, who makes the best glasspack style muffler? I've probably bought 15-20 thrush glasspacks over the years. They're okay, mainly just really cheap, but it seems like the packing blows out and I'm looking for something better than that. This is for my triton 'vic, to use in place of the catalytic converters. I find that placing a glasspack where a converter was keeps the noise level about the same, for less money, and with no added backpressure. what say you
You lost me at "in place of the catalytic converters".
In truth, please run cat's on your daily drivers...it makes a huge difference on emissions, and doesn't cost any real power.
Nitroracer
Nitroracer Dork
6/26/10 2:06 p.m.
I agree for something you are going to drive often on the street keep the cats on there. I just checked summit and saw them between $50-$60 each for anywhere from 2" to 3" pipe.
belteshazzar
6/26/10 2:20 p.m.
that's in the ballpark. Thanks fellas
Mikey52_1
Mikey52_1 New Reader
6/26/10 2:22 p.m.
David Vizard in one of his 'Horsepower' books (Vol. 1, I think), has a whole big section re: headers, mufflers and tailpipes and measuring flows and Delta P's and evaluating cats and such. I don't recall Cherry Bomb's place in the pack, but there wasn't a great deal of difference between most of the tested pieces. The trick seems to be to keep the bends full cross-section (as opposed to crushed by a bender), and not to go too small in diameter. The best results I've had have been with Summit's 'house-brand' stuff...good sound, enough quiet to keep John Law happy, long service life and low enough cost that the Finanz Ministerium didn't balk at the idea.
THAT might be the crucial point...How much are you willing to spend? Will it cause any grief with your significant other?
tuna55
tuna55 HalfDork
6/26/10 7:41 p.m.
Yuck. The glasspacks did really really badly in a hot rod test on the dyno and they sound really bad at anything other than idle, if you want my opinion. If you already have a muffler on the car, get a resonator instead of a glasspack. Cheaper and nothing to blow out.
I hate catalytic converters... leave 'em off.
kabel
kabel Dork
6/26/10 9:03 p.m.
How about Supertrapps
belteshazzar
6/26/10 9:58 p.m.
tuna55 wrote: Yuck. The glasspacks did really really badly in a hot rod test on the dyno and they sound really bad at anything other than idle, if you want my opinion. If you already have a muffler on the car, get a resonator instead of a glasspack. Cheaper and nothing to blow out. I hate catalytic converters... leave 'em off.
can you link me to the article where the straight through glasspack made a difference on a dyno?
njansenv
njansenv HalfDork
6/27/10 8:53 a.m.
tuna55 wrote: I hate catalytic converters... leave 'em off.
YEAH! Stupid catalytic converters and their ridiculous emissions reducing properties.
Now lets go out and hunt some spotted owls.
DILYSI Dave
DILYSI Dave SuperDork
6/27/10 9:15 a.m.
I like the Magnaflow Race Bullets.
And +1 on not being a douchebag who runs catless on the street.
erohslc
erohslc Reader
6/27/10 9:22 a.m.
Cats only work properly when operating at correct temperature, and with the mixture held very closely to stoic. You can't just 'bolt them on', and hope that the magic happens. Practically speaking, it requires an EFI system and an O2 sensor, running in closed loop. The OEM's have spent billions on this issue over the years, it's the main reason EFI has been universally adopted. Otherwise, running cats is a waste of money, and resources. Resources? The platinum, the cost to manufacture and distribute, and loss of motor efficiency requiring more fuel to be burned.
Carter
rF3sXSv8Y863x3dekRk9bbCSuOJHJG2AbmMbPirO6cT7hbPs6RZ1OGIEE6QhbYaB
