bravenrace
bravenrace HalfDork
3/4/09 11:02 a.m.
I haven't had to change one in many years. What brand is considered the best, and where do you guy it?
spitfirebill
spitfirebill HalfDork
3/4/09 11:56 a.m.
I've always heard Spicer were good. I put them in one of my Spitfires.
DILYSI Dave
DILYSI Dave SuperDork
3/4/09 1:21 p.m.
Normal applications - Spicer
Heavy Duty - Alloy USA (*disclaimer - I work for them)
Insane duty - CTM
bravenrace
bravenrace HalfDork
3/6/09 5:49 a.m.
Anyone know where to get any of these? All I can find is Precision (Federal Mogul) and Neapco.
petegossett
petegossett GRM+ Memberand Dork
3/6/09 6:39 a.m.
Since we're on the subject, any of you guys with access to the catalogs know it there is a u-joint available that would fit the 1961-63 Pontiac Tempest & LeMans axel shafts?
According to the guys on the Pontiac forums they're nla. I don't have the specs, but could get them if needed.
spitfirebill
3/6/09 7:08 a.m.
bravenrace wrote: Anyone know where to get any of these? All I can find is Precision (Federal Mogul) and Neapco.
I bought mine from a local driveline repair shop.
ignorant
ignorant SuperDork
3/6/09 8:19 a.m.
Any major brand is good for standard duty.. Just run away from the super junko ones @ cheapo auto parts stores.
A hint is that non greaseable joints are slightly stronger due to no holes for grease fittings. They will not last as long as a good greaseable though.
Jensenman
Jensenman SuperDork
3/6/09 10:12 p.m.
I have always had the best luck with the sealed non greaseable ones, I just pack them full at installation. There's no grease holes drilled through which reduces strength. If you think you need to grease them, drill and tap the caps for 4 individual grease fittings and squirt away.
If you get U joints with that 'clear' grease, do yourself a favor and pack them with 'real' grease before installation. BTDT.
benzbaron
benzbaron Reader
3/6/09 11:17 p.m.
I'd like to find a replacement U-joint for the mercedes. I called up a shop and they made it sound like a big deal, but my old man is an expert with a press and could do the U-joint no problem. I'd just hate to pull it open only to find out the part is NLA.
When you test the U joint you just move it back and forth and feel if anything is binding, right? Mine felt a little sticky in one direction.
Good topic!
foxtrapper
foxtrapper SuperDork
3/7/09 7:00 p.m.
A number of 4x4 boards have praise for the Neapco units.
AJMPTNU5N2nEudRobpMEptXfCXboeKK0vbAna1CES5yCKGZnfTSM5u2Iz6iVmYcf
