10/15/10 10:55 a.m.
considering I have 235s stuffed under the corners of my e36.. I am sure 245s will fit under the 1er
Giant Purple Snorklewacker
10/15/10 11:00 a.m.
mad_machine wrote: considering I have 235s stuffed under the corners of my e36.. I am sure 245s will fit under the 1er
I ran 245/40-17s at all 4 corners of my E36 M3 without clearance issues (until I cranked in camber for the track, then needed spacers).
jstein77
jstein77 Dork
10/15/10 11:11 a.m.
mad_machine wrote: same chassis as the 3 series.. just a shame we don't get the pretty 1.. the 3 door hatch. The 4 door is ugly and the coupe looks scrunched
Actually, according to Jalopnik, we are getting the pretty 3-door.
Matt B
Matt B HalfDork
10/15/10 2:10 p.m.
Now, there's a new car I'd actually be willing to buy.
My biggest problem with the 1-series is that it isn't that much different in content than the 3-series. The hatch changes that. It also gets rid of the coupe's awkward rear styling.
dj06482
dj06482 GRM+ Memberand Reader
10/15/10 2:15 p.m.
pigeon wrote: I think they are trying to tune the chassis response to understeer at the limit by specifying a relatively narrow tire at the front. There are other reasons, like fuel economy (less frontal area and rolling resistance) and being able to go with narrower (cheaper/lighter) wheels.
All good points, I understand the need to reduce costs, and improve fuel economy whenever possible. However, I would suggest that they could use the Sport Package as an excuse to put some decent-width rubber under the car. I wouldn't expect to see it across the entire model line, but would at least like to see it as an option. The 335i/is gets killed in comparos when it's going against Audi S4s with AWD with 255 width tires up front. And while I'm on my soapbox, I'd like to see some kind of an LSD (mechanical, preferably) available as at least an option on the 1 and 3 series. This way, when I buy a fully depreciated one in 15 years, I won't have to do much to it
10/15/10 8:25 p.m.
an optional LSD would be great.. but aside from the true M cars.. BMW has not made one availible since early 1996. I know, I have one of the last non-M cars with an LSD from the factory. My Ti was built in Feb 1996.. it was not too long after that time that they went to Traction control
nderwater
nderwater HalfDork
10/15/10 11:25 p.m.
My friend the BMW tech doesn't have much good to say about those engines, other than they're fast. Apparently the turbos trigger 'limp mode' at the drop of a hat and are really time consuming (expensive) to troubleshoot and repair.
CLH
CLH GRM+ Memberand New Reader
10/16/10 10:54 a.m.
jstein77 wrote: Actually, according to Jalopnik, we are getting the pretty 3-door.
Dude, that Jalopnik article was from January of 2007. Loss of style points for getting my hopes up for the 3-door.
10/16/10 10:54 a.m.
yes.. once they get hot.. fun time is over. If you could manage the heat better, they would be a lot more fun
LJD
LJD New Reader
10/16/10 2:29 p.m.
mad_machine wrote: yes.. once they get hot.. fun time is over. If you could manage the heat better, they would be a lot more fun
Isn't the 1M supposed to get an upgraded oil cooler?
nderwater
nderwater HalfDork
10/16/10 8:49 p.m.
From what I remember he mentioned combustion buildup on the intake valves (he said this is becoming common on direct injection engines - fuel in the intake stream helped keep these clean on older engines), as well as issues with the turbo plumbing and gremlins in the ECU.
neon4891
neon4891 SuperDork
10/16/10 9:39 p.m.
Am I the only one here that likes the looks of the 1?
ansonivan
ansonivan HalfDork
10/16/10 10:00 p.m.
Yes.
I'd still hit it though, with a truck.
CLH
10/17/10 10:02 a.m.
neon4891 wrote: Am I the only one here that likes the looks of the 1?
Nope.
irish44j
irish44j HalfDork
10/17/10 10:32 a.m.
I hate them from a looks standpoint. The 3-series even in base form, if not terribly aggressive or original-looking, is still very stylish and flows well. The 1-series looks like the front end is a miniature X3. And I still can't get over the "saggy belly" lines of doors/rockers. I may be one of the few that thinks
Give it a more aggressive front end (especially the "cute" headlights), straighten out the lines on the side, drop a few hundred lbs (it doesn't need to weigh nearly as much as a 3-series) and then I'll reconsider my opinion.
irish44j
irish44j HalfDork
10/17/10 10:44 a.m.
Here's a quick PS of a few small stylistic changes that would make the 1-series look SO much better/more agressive and not so girly.
Only thing I changed is the headlight shape and the rocker-door seam lines.
before:
after:
z31maniac
z31maniac SuperDork
10/17/10 11:11 a.m.
^I like your vision.
Matt B
Matt B HalfDork
10/17/10 8:08 p.m.
^Me too. So does the wife.
When I originally showed her the hatchback she said, "what the hell is going on with that curved line between the fenders?"
"Flame surfacing" is a dangerous design aesthetic, doing more wrong than good on most occasions. I don't have a problem with the concept, just the execution.
LainfordExpress
LainfordExpress New Reader
10/17/10 8:20 p.m.
But the flame surfaces!!! Haven't your heard? It's a German car! It is too efficient for your photoshopping.
KBDRwhY76GNB5HFk2ZDJETI1D2JSfOF6zdszPQQQ14U75Gc3TL808rJuq0HRsj3c
