SnowMongoose
SnowMongoose Dork
10/25/15 12:31 p.m.
Valve stem on the TPMS seized up, sourced a replacement via ebay.
During the install process this little metal dealie broke off.
Any reason not to hit it with the ol' soldering iron?
(assuming I can find my soldering iron, but that's neither here nor there)
Would really rather not shell out for a 5th cloned TPMS sensor, yay Mitsu.
sassyness77
sassyness77 New Reader
10/25/15 12:38 p.m.
In reply to SnowMongoose: It should work fine, I know we've just pinched them under the stem in the past even just to make contact and it still functioned fine.
2.0dohc
2.0dohc Reader
10/25/15 12:40 p.m.
Its already broke, what do you have to lose?
SnowMongoose
SnowMongoose Dork
10/25/15 1:03 p.m.
In reply to 2.0dohc:
Paying to have someone spend five minutes popping the bead and installing a new sensor after the solder doesn't hold up to rotational forces.
As opposed to biting the bullet now and having a fresh sensor installed.
oldopelguy
oldopelguy SuperDork
10/25/15 1:37 p.m.
You could solder it up and put it in the spare....
SnowMongoose
SnowMongoose Dork
10/25/15 1:47 p.m.
In reply to oldopelguy:
Ooh, good point!
Knurled
Knurled GRM+ Memberand UltimaDork
10/25/15 2:48 p.m.
I'd be looking into getting a big long worm clamp like some Fords have. Clamp that sucker in. That is assuming that cyanoacrylate won't hold it in.
qsf3Ef6pdw3gpowMXwnwz0QJuIQxMoClFTPBbrFTV0mluuq2ZMzTrN79OJtKDqgA
