Trackmouse
Trackmouse SuperDork
3/8/17 8:27 p.m.
In particular, Can you smash two different flare fittings together? I have an adapter that goes 3/8-24 "standard flare" male to m10x1.0 bubbles flare, female. The metric Side needs to be inverted flare.
Side question- is a "standard" flare just a single flare?
Streetwiseguy UltimaDork
3/8/17 9:01 p.m.
No.
Side question- No. Double flare.
Let me get this right- The 3/8 is a double flare, male on the line, into a female adapter. Other end is a male end on the adapter, female bubble flare fitting on the line? Or vice versa? The lines are regular old 3/16 and 5mm?
I think you would be way farther ahead to use either metric or standard, and reflare one of the lines to match. Cut off the metric bubble, get a 3/16 nut and double flare the line.
Trackmouse
3/8/17 9:27 p.m.
Oh, and yes I have a brake line flaring tool, but it's the el cheapo 7 piece flare tool from HF. I have my doubts about flaring lines (the tool's and my own ability).
This is why I like to do things via adapters. It's all reversible, I don't have to flare, cut, and potentially destroy any brake lines, nor do I need to bend any line.
3/8/17 9:30 p.m.
Flaring lines isn't that difficult. It's all about the prep - a square cut with a bit of a bevel on it.
Trackmouse
3/8/17 9:32 p.m.
I guess I should just tell people what I'm trying to accomplish.
The Toyota (m10x1.0 inverted flares) needs an adjustable prop valve. There isn't anything available in that thread and that flare. So I can get a willwood unit in m10 bubble flare. Or adapt to the 3/8-24. Which will involve cutting, flaring, bending, etc.
Does nobody make an inexpensive, metric, adjustable ABPV for Japanese compacts? I see Pegasus does but they want you to buy seperate adapter fittings, which puts me right into the same boat for more money. Looking to keep this under 100$.
3/8/17 9:35 p.m.
patgizz
3/8/17 9:36 p.m.
Parts store should have a brass adapter fitting, no? I got them for putting sae 3/16 line into a wrx combination valve at advance.
http://www.dormanproducts.com/c-176-brake-line-adapters.aspx
Trackmouse
3/8/17 9:39 p.m.
Keith Tanner wrote: Ooo, I know the answer to this one. https://www.flyinmiata.com/complete-adjustable-brake-proportioning-kit.html
Oh, Keith! Bless you Father Miata!
3/8/17 9:41 p.m.
Metric 10x1.0 inverted flare to NPT is a surprisingly difficult adapter to find. We have to have ours custom-made, I've never come across one in the wild. The SAE version is everywhere.
Trackmouse
3/8/17 9:42 p.m.
In reply to patgizz:
I been all over the Internet for this. And the parts stores. Sadly, nearly all the staff can't even begin to comprehend the incredibleness I'm trying to achieve.
Trackmouse
3/8/17 9:49 p.m.
Hey Keith, placed my order. Thanks again man. You literally solved like 3 days of Internet scouring.
3/9/17 8:19 a.m.
I'd love to know what your search terms were so I can make our stuff easier to find. Glad I could help.
Trackmouse
3/9/17 1:41 p.m.
Typed "m10x1.0 inverted flare to 3/8-24" and added on the end for each search the words "coupler/adapter/proportioning valve" also tried "metric adjustable brake proportioning valve", "Toyota adjustable brake proportioning valve", and, finally, I resorted to simplifying the search terms to things like "m10 proportioning valve" or "import wilwood valve". Even "m10 to 1/8" npt fitting". various forum threads would come up, apperently the Honda guys have this same issue.
BrokenYugo
BrokenYugo MegaDork
3/9/17 3:37 p.m.
Side question answer: No, single flares are not acceptable for braking systems (neither are compression fittings, while we're on that matter), the inverted/double flare is a two step process.
3/9/17 9:44 p.m.
Trackmouse wrote: Typed "m10x1.0 inverted flare to 3/8-24" and added on the end for each search the words "coupler/adapter/proportioning valve" also tried "metric adjustable brake proportioning valve", "Toyota adjustable brake proportioning valve", and, finally, I resorted to simplifying the search terms to things like "m10 proportioning valve" or "import wilwood valve". Even "m10 to 1/8" npt fitting". various forum threads would come up, apperently the Honda guys have this same issue.
Gotcha, thanks. I never considered M10. I'll make it easier to find.
nMDvIzTNk3WgPaml2vpyV9zQcy8Zg4pI3D8HsWQ29aWrPdFgemGDlS03krfB1Yee
