aussiesmg
aussiesmg HalfDork
12/14/08 10:03 a.m.
I need an option for the $2009 Challange but a T5 will not cope, T56 are too expensive and many are not tough enough also, anybody got an option, auto is a last resort guys.
patgizz
patgizz GRM+ Memberand Dork
12/14/08 10:59 a.m.
for the 'maro?
4 speed T10/Super T10
MadScientistMatt
MadScientistMatt HalfDork
12/14/08 7:26 p.m.
What engine is it going behind?
aussiesmg
aussiesmg HalfDork
12/14/08 7:29 p.m.
400 ci SBC internally balanced
Trans_Maro
Trans_Maro New Reader
12/14/08 10:52 p.m.
Super T-10's aren't exactly cheap anymore but they are cheaper than a T-56. Around here thye usually got for about $750.00 for one that doesn't sound like something awful happened to it.
If you're nice to it, a Saginaw might survive but I doubt it.
Shawn
Junkyard_Dog
Junkyard_Dog Reader
12/15/08 7:47 a.m.
NV4500 or something? Check and see what truck transmissions the rock crawlers are using these days.
Jensenman
Jensenman SuperDork
12/15/08 8:25 a.m.
Maybe it's not the most ideal setup, but don't forget the old 3 speeds. I just picked up an old Mercury Cougar toploader 3 speed, flywheel/clutch/tranny/floor shifter/driveshaft for $200.00.
stumpmj
stumpmj Dork
12/15/08 8:54 a.m.
TH350 or TH400 with a ratchet shifter?
P71
P71 GRM+ Memberand HalfDork
12/15/08 9:01 a.m.
TH350 or 400 with manual valvebody and ratchet shifter for sure!
I'd look at T5's again. There's a ton of rebuilt ones floating around out there (for Fords anyways) that are beefier then stock for dirt cheap.
Travis_K
Travis_K Reader
12/15/08 9:17 a.m.
Get an auto, any 4/5/6 speed that will hold up behind a uilt small block will be $1k or more unless you are really lucky.
John Brown
12/15/08 2:42 p.m.
Plus 777 for a well done 'glide/TH350/400/
aussiesmg
aussiesmg HalfDork
12/16/08 9:32 p.m.
I have a built T350 but really want a manual, the car is going to continue in my ownership and be used for a multitude of events
P71
12/16/08 10:00 p.m.
Swap in a proper manual after the Challenge. I'd still look at T5's! There's a lot of them out there that were in race cars and are now selling cheap...
aussiesmg
aussiesmg HalfDork
12/16/08 10:07 p.m.
Any hints on where to look for a tough T5
P71
12/16/08 11:29 p.m.
Mustang forums. Slap a GM bellhousing on it. Try craigslist too, I've found two there very recently.
aussiesmg
aussiesmg HalfDork
12/17/08 8:11 a.m.
I was under impression the mustang T5 has a very different output shaft?
P71
12/17/08 9:17 a.m.
It might, but Mustang/Ford driveshafts and yokes are super-easy (I have 3 laying around) to find. It's an engine-swapped car already!
QorqkmUdKQR5bYb6XtrtwrC2AkNSWtUvHOCGS5HTDqcvCi6migVHnS36oCYeRMzU
