93celicaGT2
93celicaGT2 SuperDork
2/27/10 2:10 p.m.
Where do you all buy your injectors? The 440s i have now aren't going to cut it for a whole lot longer, and i'm looking at going quite a bit larger just so i don't have to keep buying them every time i upgrade.
aussiesmg
aussiesmg SuperDork
2/27/10 4:46 p.m.
Yepper, plenty of them from RX7s.
Do you know what they rate in lbs, cause I have some 18lb ford ones laying about
digdug18
digdug18 Reader
2/27/10 6:10 p.m.
LB to CC conversion
18Lb injectors is 189cc's per minute.
As for cheap ones, alot of people use the turbo DSM ones for added cc's, but people are starting to catch on to the fact they are cheap, and the price is going up. Best bet, look on all the forums.
Andrew
93celicaGT2
2/27/10 6:17 p.m.
The DSMs are too small.
I'm looking for maybe 800ccs. 550s are absolute minimum, but i'm sure i'll outgrow them within a year, so i'd rather just spend the money once.
aussiesmg
aussiesmg SuperDork
2/27/10 6:34 p.m.
Mazda will work, 760 IIRC
93celicaGT2
2/27/10 7:32 p.m.
760 would be fine... what do i get it out of?
Jensenman
Jensenman SuperDork
2/27/10 8:23 p.m.
I found this a while back, maybe it will help.
http://users.erols.com/srweiss/tableifc.htm
digdug18
digdug18 Reader
2/27/10 8:55 p.m.
Precision 660cc injectors for $190
Precision 1000cc injectors for $225
Both for honda applications, but I'm sure you could use them for yours as well.
Andrew
tnturbo
tnturbo New Reader
2/28/10 3:26 a.m.
Going from memory here and it has been since the 90s since I thought about these really, but lots of the older throttle body injection Fords (Ford called it CFI) had injectors in 45-50lb range in non HO V8s (forget exactly) and should be dirt cheap at pull a part yards. The V8s each had 2, think early/mid 80s LTD. 84/85 5.0 auto Mustangs had even larger versions but would be harder to find. The 2.3 HSC Ford engines the sort that came in Tempos not the Mustang 2.3 had Bosch injectors in the 55lb range. 2.3 HO HSC and 2.5 HSC had an injector around 65lbs.I'm wanting to remember something being strange with the resistance on the Tempo injectors, but again they should be dirt cheap.
Mitsubishi Starion and Conquest had really big injectors.
sobe_death
sobe_death Reader
3/1/10 9:44 a.m.
If I were going that large, I would save up and buy a set of Injector Dynamics injectors. They aren't that expensive and they range from 750-2000cc with stupid response times and atomization., and can be used with over 130psi of fuel pressure
MadScientistMatt
MadScientistMatt Dork
3/1/10 10:52 a.m.
What motor is this on? There's a couple different physical sizes, and some injectors that are cheap to find may not fit.
Paul_VR6
Paul_VR6 Reader
3/1/10 2:29 p.m.
I have a box (10 maybe) of those Ford CFI injectors if you want to double them up. Make an offer.
93celicaGT2
3/1/10 2:49 p.m.
MadScientistMatt wrote: What motor is this on? There's a couple different physical sizes, and some injectors that are cheap to find may not fit.
F2T. Looking for something that'll play nice with that motor and one of your DIY PNP kits.
zipty842
zipty842 Reader
3/1/10 3:11 p.m.
I just bought new reman'd injectors from Rock Auto. GB Remanufacturing brand, $40/each including core.
6tLHT6jvPehs0uR2aIYH0YKhn6eC5mDQmqH84hlQTh4ZGgYW5zV9j9q4DDzY9hRt
