1 2 3 4 5
Snrub
Snrub New Reader
12/24/13 8:44 a.m.
Brett_Murphy wrote: Think about how many BMWs were produced versus RX-8s, though. Plus, the Germans seems to have better long term availability for parts than the Japanese for some reason.
How long term is "long enough?" :) I sold my '87 FC 4.5 years ago and to my knowledge every part was still available from Mazda. That's 22 years. At that point I believe most FB parts were still available, but they had stopped selling 12A rotor housings.
mrybczyn
mrybczyn New Reader
12/24/13 9:46 a.m.
kanaric wrote: Mazda shouold just re-release the RX8 as a MX8? with a 6 cylinder. They would have takers since that chassis is already so much better than a 350 or 370z and looks much better as well. You would also probably go from a unreliable terrible MPG torqueless engine to somethat that is the total opposite and you would then have near the perfect sports car since it already weighs near the same as a FRS
This.
A real sportscar with room in the back.
I'll take two.
Swank Force One
Swank Force One MegaDork
12/24/13 9:48 a.m.
Soo... what Mazda 6 cylinder will they use?
Knurled
12/24/13 10:11 a.m.
kreb wrote: RX-8 prices have dropped so much that they might be worth looking at as track rats even with the Rotary, seeing as being flogged is one thing that the engine happily does - if you can afford the fuel.
Rotaries are only inefficient at low load/part throttle.
Under WOT they can approach Diesel-like BSFCs. Especially the ones with fun porting. (I've seen SAE papers with BSFC in the .42-.45 range)
UNfortunately for the RX-8, the engine precludes fun porting, so the first step should be to rip the Renesis out and install a proper engine with one big exhaust port and one big intake port per rotor.
See, I drive bridge ports for the fuel economy benefits...
alleykat
alleykat Reader
5/13/14 6:54 p.m.
More details are forthcoming
First completed RX8 with the GM LFX
MattP
MattP New Reader
10/15/14 9:04 a.m.
alleykat wrote: More details are forthcoming First completed RX8 with the GM LFX
Were the details ever released?
I feel like whoever is first to develop a plug and play swap kit for the RX-8 will sell a ton. Unfortunately it still seems to be a case of piece it together from 5 different vendors or pay a shop $$$.
I say that as someone that daily drives a stock RX-8 and really likes it...
unk577
unk577 Reader
10/15/14 9:47 a.m.
They have a running swap in a NB miata that they drove cross country the day after they got it on the road. They are finishing up some details on the swap which I would think will carry over to the RX8.
http://forum.miata.net/vb/showthread.php?t=553881&page=4
"The NB is our development chassis and at this time we have not fitteld this package to the NA. Speaking from the V8 conversions it will be a tight fit and will require the hood bracing trimmed. If you take the measurement at the highest point on the V8 the difference is about .250 less on the NA. Running the LLT intake will provide an additional .750 clearance over LFX intake manifold. The LFX intake has a bit of additional material that will allow for trimming which may also help.
We are working for a CARB EO # and at this time... looks very positive for early spring. I am doing a new wiring harness that conforms to standard. In my hast to assemble the car I omitted a couple needed circuit's that are necessary.
At this time I can have one on one approval for the LFX conversion in the MX5 chassis. This will allow for cars to be built!
Updates on the drive line are ongoing and the sway bar and shock package are being fine tuned...........Hope this helps
Steve"
wspohn
wspohn HalfDork
10/15/14 10:35 a.m.
So you want power but like the stock gauges etc.
What about a Mazdaspeed turbo engine out of a Mazda 3? I understand that using them in an in line configuration involves accommodating the bump at the back of the engine (high pressure pump?) so you might have to notch the firewall. but you'd get to keep your trans and possibly ECM (unless you needed to swap out to a Mazdaspeed ECM). Easy to get over 300 bhp out of that engine.
alleykat
alleykat Reader
10/16/14 11:27 p.m.
The original target for release was this spring. I think the price of the lfx will not be more compelling than an lsx swap. The swap will also require a differential too. And that is before you deal with the can-bus. Then you have fuel, exhaust, etc. I find an E36 lsx swap a more budget friendly endeavor with a chassis that is capable enough. Vorschlag has sold around 100 of these swap kits and continues to develop them. In fact, they quoted me a turn key price of $22k to $26k with me providing the car.
If I provide the labor, this swap could run me $15k or less. I don't have fabrication skills or time to do it for challenge money.
10/16/14 11:59 p.m.
Interesting - around 100 kits for the E36? We've sold more than that for the Miata.
I agree that price will not be the reason to use the LFX instead of an LS. It'll have to be some other attribute.
kanaric
kanaric Dork
10/17/14 12:23 a.m.
LS E36? I would really like a LS E34.
Strike_Zero
Strike_Zero SuperDork
10/17/14 2:14 a.m.
In reply to Keith Tanner:
It may have to do with price of their kit more than anything. That and the introduction of some cheaper kits that hit the market. There is a swap kit available now that cost less than a set of Vorshlag headers.
alleykat
alleykat Reader
10/17/14 7:05 p.m.
Strike_Zero wrote: In reply to Keith Tanner: It may have to do with price of their kit more than anything. That and the introduction of some cheaper kits that hit the market. There is a swap kit available now that cost less than a set of Vorshlag headers.
Please share that info.
Strike_Zero
10/18/14 5:49 p.m.
CX Racing E36 LS1 Stuffs
Bimmerforums Thread: Warning - Some trolling is in that thread.
dean1484
dean1484 UltimaDork
10/18/14 8:36 p.m.
I have wanted to take the millenia s motor and re grind the cams and then add a relatively miled turbo. Take that and somehow put it in a RX8.
don't ask me why I want this. There is no good reason to do this swap. I just think it would be cool.
alleykat
alleykat Reader
10/19/14 6:45 p.m.
Strike_Zero wrote: CX Racing E36 LS1 Stuffs Bimmerforums Thread: Warning - Some trolling is in that thread.
Many thanks good sir!
fidelity101
fidelity101 SuperDork
10/20/14 3:34 p.m.
anyone who wants to buy an rx8 to put in XYZ engine. Please contact me and I will gladly take the engine/engine harness off your hands to ease your swap fundage.
ProDarwin
ProDarwin UltraDork
10/20/14 3:36 p.m.
dean1484 wrote: I have wanted to take the millenia s motor and re grind the cams and then add a relatively miled turbo. Take that and somehow put it in a RX8. don't ask me why I want this. There is no good reason to do this swap. I just think it would be cool.
Regrind to make it an Otto Cycle?
John Brown
John Brown MegaDork
10/6/16 10:34 a.m.
Bringing up a two year old thread...
Has the RX8 power production to cost ratio gotten better?
Is there a header/junkyard turbo/charge cooler that is affordable?
Was the Can-bus problem alleviated?
Asking for a fiend.
kb58
kb58 Dork
10/6/16 10:46 a.m.
I'll bit - I don't understand doing 99% of the work to install a V6, when going to a less-stressed V8 is just 1% more effort. I get it that it (probably) weighs less, and is (probably) less expensive, but these cars aren't Formula V's, and what's another 30 lbs when you've got 430 hp.
John Brown
John Brown MegaDork
10/6/16 10:58 a.m.
I'm good with that answer ;)
My dream was a Mazda MZI V6 (Ford Duratec) prepped like a Noble M400 (twin turbos) into a NC or a RX8. It is silly for certain, but it's also quite possibly doable.
Robbie
Robbie GRM+ Memberand UltraDork
10/6/16 11:00 a.m.
In reply to John Brown:
I support this plan, but have very little info for you.
kb58
kb58 Dork
10/6/16 11:03 a.m.
John Brown wrote: Asking for a fiend.
I'd believe that ;)
NOHOME
NOHOME PowerDork
10/6/16 11:58 a.m.
JtspellS wrote: So have you driven a rotary at all, or are just going by hearsay?
You mean they CAN be driven? Your kidding right?
NOHOME
NOHOME PowerDork
10/6/16 12:03 p.m.
1 2 3 4 5
FxOLtu1VkUOD2OcVPUzmvypNDV2wSEybGQV2PJJgl3k5wporxKxHdaIpdJrkvmjd
