COMMON TOOLS DEFINED
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilser which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh ****..."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminium sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines , refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling 'DAMMIT!' at the top of your lungs. It is also, most often, the next tool that you will need.
CQTM (chuckle quietly to myself)
I have heard some of those in the past, but some were new to me. always good for a laugh.
I would guess from the description of the drill press and the aviation tin snips. that the author is a member of the EAA (experimental aircraft association) and is / was involved with building his own plane.
Whatever the source, that boy has done some metal work. I laughed, but in a painful memory kind of way.
Here's the original list from Peter Egan's column in Road and Track in April 96
Hammer: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive car parts not far from the object we are trying to hit.
Mechanic's Knife: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing convertible tops or tonneau covers.
Electric Hand Drill: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling rollbar mounting holes in the floor of a sports car just above the brake line that goes to the rear axle.
Hacksaw: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
Vise-Grips: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
Oxyacetelene Torch: Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the Whitworth socket drawer (What wife would think to look in there?) because you can never remember to buy lighter fluid for the Zippo lighter you got from the PX at Fort Campbell
Zippo Lighter: See oxyacetelene torch.
Whitworth Sockets: Once used for working on older British cars and motorcycles, they are now used mainly for hiding six-month old Salems from the sort of person who would throw them away for no good reason.
Drill Press: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against the Rolling Stones poster over the bench grinder.
Wire Wheel: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Django Reinhardt".
Hydraulic Floor Jack: Used for lowering a Mustang to the ground after you have installed a set of Ford Motorsports lowered road springs, trappng the jack handle firmly under the front air dam.
Eight-Foot Long Douglas Fir 2X4: Used for levering a car upward off a hydraulic jack.
Tweezers: A tool for removing wood splinters.
Phone: Tool for calling your neighbor Chris to see if he has another hydraulic floor jack.
Snap-On Gasket Scraper: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z Out Bolt and Stud Extractor: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
Timing Light: A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys.
Two-Ton Hydraulic Engine Hoist: A handy tool for testing the tensile strength of ground straps and hydraulic clutch lines you may have forgotten to disconnect.
Craftsman 1/2 x 16-inch Screwdriver: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
Battery Electrolyte Tester: A handy tool for transferring sulfuric acid from car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
Aviation Metal Snips: See Hacksaw.
Trouble Light: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin", which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
Phillips Screwdriver: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads.
Air Compressor: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Abingdon, Oxfordshire, and rounds them off.
Grease Gun: A messy tool for checking to see if your zerk fittings are still plugged with rust.
Multimeter: A tool used for drawing blood, generally after attempting to pierce the insulation of a small wire with its sharp, sharp probe point.
Impact screw driver: A multi-use tool used to hold fingers in place for smashing, while attempting to round out a slotted or phillips head fastener (see "hammer" and "screw driver" variants.)
As a prior aircraft mechanic, I can tell you that whoever wrote it was almost certainly an A&P guy. Lots of aircraft references. I've seen this list for years on different forums, modified to fit the context. I motorcycle references for bike sites and so on.
Fun and true at the same time; perfect humor.
John
It's definitely Peter Egan, I remember reading it in R&T over a decade ago. It's also reprinted in his "Side Glances" books. Such a shame that his most popular work never gets the correct attribution.
Loctite: Used for jamming on bolts that need to stay on a little tighter and giving a false sense of security about bolts that need to stay on a lot tighter.
Ratcheting socket wrench: A slapstick comedy prop.
Car tire foot pump: A device that pumps air into tires using force applied by the foot. Generally lasts about 40 minutes of pumping time before something on it explodes and releases the air from the tire you're working on.
Compact bicycle tire pump: A simple and reliable tool for destroying tire valves and developing arm muscles that often steps in when the foot pump fails.
Xenon flashlight: Used for casting a large shadow on what you're working on. Also a handy portable power source for electrical testing in the dark.
Hand vice: Used for shattering distributor rotors off their shafts and almost fitting around things.
Penetrating oil: Used for lubricating the head of a bolt that is stuck on, making it easier to round off.
