dansxr2
dansxr2 Reader
3/26/09 9:06 p.m.
Here's what I got to repair it with. Photobucket
Anyone had experience with a keensert? I'll post results and take pics of installation.
friedgreencorrado
friedgreencorrado Reader
3/26/09 11:43 p.m.
I tried searching for a page with a DIY, but I just noticed Google's removed the `don't return results from domain' selection on the advanced search. Without being able to screen out .com, .co and .biz, all I get is 540834587334857238975 results from people trying to sell me one of the damn things.
Sigh.
SVreX
SVreX SuperDork
3/27/09 5:39 a.m.
Looks something like a Heilicoil. If so, you drill an oversized hole, thread the hole with a tap, and screw it in with a special insertion tool.
dansxr2
dansxr2 Reader
3/27/09 6:38 a.m.
yeah u drill it out, and tap to the OD and screw it in. then knoxk the stakes on it in and its good to go. I'll stick some re thread locker on for good measure too.
nickel_dime
nickel_dime HalfDork
3/27/09 7:53 a.m.
The hole you drill for a keensert is generally larger than the normal tap drill size of the normal thread. In other words (using general sizes here as I haven't looked it up) a 1/4-20 keensert would take a 3/8-16 tapped hole to screw into. The tap drill size for 3/8-16 is 5/16. You would need to drill at least 1/64 to 1/32 larger hole then tap it with a normal 3/8-16 tap. The minor diameter on the external threads of a keensert are larger than they would be on a bolt so you have to drill the hole slightly larger so that the threads in the hole don't come to a point.
I found this site with with the tap drill info for metric keenserts. http://www.newmantools.com/kee.htm#knmlink
Also be very careful when tapping in the tabs, they bend very easily. Use a punch and lightly tap them in one at a time. There is no need for a thread locker compound. The tabs give you a mechanical lock much stronger than any thread locker.
Good luck and pray you never have to take it back out.
dansxr2
dansxr2 Reader
4/15/09 11:11 p.m.
Fixed. Pulled the head to drill as the 31/64th" bit was a bit too long. Wow that was easy!!
friedgreencorrado
4/16/09 12:18 a.m.
dansxr2 wrote: Fixed. Pulled the head to drill as the 31/64th" bit was a bit too long. Wow that was easy!!
Good work. Cheaper than finding a new head, right?
Paul_VR6
Paul_VR6 Reader
4/16/09 7:19 a.m.
Probably not, counterflow heads are a giveaway. Cheaper then a headgasket though ;)
VWguyBruce
VWguyBruce HalfDork
4/16/09 7:46 a.m.
Nothing more satisfying than averting disaster.
I was just considering a G60 head for about $50 to get the smaller diameter valve stems, perception of higher flow. Not worth it Paul?
16vCorey
16vCorey SuperDork
4/16/09 8:52 a.m.
Not for him, he'd just boost the crap out of it!
VWguyBruce
VWguyBruce HalfDork
4/16/09 8:57 a.m.
Haha, for me it would be for a NA motor.
Paul_VR6
Paul_VR6 Reader
4/16/09 10:13 a.m.
I think everything hydro lifter already has the 'small' stems, only early solid ones have the 8mm. The only difference in the G60 head is that it comes off easier due to a Corrado's inherent nature to part itself out.
friedgreencorrado
4/16/09 11:02 p.m.
Paul_VR6 wrote: Probably not, counterflow heads are a giveaway. Cheaper then a headgasket though ;)
Ah, you're right. I forgot it was just an 8v with funny pistons or something.
44Dwarf
44Dwarf Reader
4/17/09 5:44 a.m.
MSC sell keeneserts there great in places you can't aford for a fit to back out like regular helicoils do. On a side noe helicoil make some whith a seraded buttom 2 coils to lock in better but known buys them as there more $.
16vCorey
16vCorey SuperDork
4/17/09 7:47 a.m.
Paul_VR6 wrote: I think everything hydro lifter already has the 'small' stems, only early solid ones have the 8mm. The only difference in the G60 head is that it comes off easier due to a Corrado's inherent nature to part itself out.
Actually, IIRC from my head porting days, all counterflow heads (including Corrado) had the 8mm stems. ABA's had the 7mm stems, and it was a semi popular upgrade to put the ABA guides and valves in the counterflow heads when building one up.
Paul_VR6
Paul_VR6 Reader
4/17/09 12:16 p.m.
I can't remember anymore, those heads just go to 'the pile' and never return from China.
m4ff3w
m4ff3w GRM+ Memberand Dork
4/17/09 1:00 p.m.
I like the Keen serts, but they are so expensive (or at least the kit with the tool is)
After having a Helicoil back out of the Fiat's head, I used EZ-Loks. I was very impressed.
dansxr2
dansxr2 Reader
4/20/09 1:54 p.m.
well the car is running great now that i got the new lower timing gear and correct cam gear with the new tensioner and belts.. And here goes my luck, now the transmission that I installed less than 2000miles is acting up. it won't pull until 4k in any forward gear. Reverse works. Any idea? I'm looking at replacing it with a '93 Talon TSI or a '96 Integra
p9yGklNnz6xbXGvYB739YiUxxRBaUOp7alkTPFuSAHYum2gYnqKqYW82RosTF3UT
