I'm searching for an engine donor for the Free RX8 Challenge car.
What's a good cost per horsepower ratio?
Would a 2004 Northstar V8 (producing 320hp) be a good candidate for a donor engine? I can get this one in Indianapolis for $848.51 all in.
It has a $475 " Buy it Now" price. What do you guys think?
Absolutely, 1000% stay away from Northstar engines. They leak oil like sieves.
I'd determine your target power numbers and work backwards from there. Turbo Atlas motor is absurd HP for relatively cheap, but it might be more power/fabrication than you need
I 2nd the stay away from the Northstar. I work at a Caddy dealer and unfortunately am one of the guys that gets pinned with those E36 M3boxes. You will be doing valve covers and half cases every six months to slow the oil leaks down.
In reply to calteg :
This is a one and done type of thing. I won't be owning the car after the Challenge. So oil leaks (as long as not massive) shouldn't be a problem. I need a donor that I can pull and swap "as-is" no fabricating turbo bits etc.
I thought by 2004 they had made significant improvements to the NorthStar.
They made them run better but never fixed them. Guys hide from the dispatcher every time one rolls up on the service drive. Line for the bathroom lol.
calteg said:350 Chevy
Can I get 320hp for $848.51* from a SBC?
*(including a transmission attached)
In reply to eastpark :
Thanks for pointing me to that. I hadn't seen that one yet. I'll put it on the watch list for later tonight.
Indy - Guy said:calteg said:350 Chevy
You can make more power for less money with a SBC, if you're willing to put the sweat equity in.
I have to think that a 4.8 ls is the answer to this question. I see them all day with transmissions for $600 and if you see it run before they pull it, I don't see where you can go wrong.
There are ways to remove VATS for free if it is counted for challenge budget.I would argue that HP tuner credit cost should NOT be counted since it is just a tool, same as a angle-grinder or a milling machine that you happen to have laying around the shop
Of course this would be with a 4l60E gearbox if that matters. Manual gearboxes for an LS seem to be well above the cost of a challenge car.
From what I remember for the rwd northstars, 2008 and up was better bc you could use hptuners. Also 2008 and up was supposed to have better head bolts or studs and less head gasket issues. But still seems like a issue for all years.
