I am working to swap an ecotec into a Mercedes 190e. I have it so it almost fits. So close.
I switched to this type of oil pan and trimmed the fins back.
I still need 1-2" for it to fit, over the subframe and steering arms. so I am thinking of cutting into the front subframe, I have trimmed the "lip" where the two stamped pieces come together. But still is too big.
what is the best way to do this? Just cut it down to where I need it, and then box it back in at the lower hight with the same thickness of steel?
Can you get a view showing the crossmember looking at it from the transmission tunnel? Then mark up where you want to cut?
Without having that, I think your plan sounds reasonable as of now.
Instead of just boxing it back in, when i did the miata i cut a few pieces of 1x1 square tube. Plug welded through the existing crossmember at a ludicrous number of places, stitch welded them together, etc. Pretty much tried to make a honeycomb or steel inside the sectioned crossmember.
Tack weld some sort or bracing/reinforcement so that when you cut out part of the crossmember, it doesn't spring into some weird new location. It's surprising the stresses that are in a component. Remove when done.
Good advice from all. Thanks.
I will try to get some better pictures later this week.
before I cut the top back I will try to weld some angle iron on the bottom.
I like this idea. Do you recall what thickness of metal you used?
