Ranger50
Ranger50 MegaDork
10/14/21 5:02 p.m.
Cliff notes: my daily driver Avalanche broke a transmission, repaired with a used version, and I'm driving again after 2.5 days.
Much longer version of this sordid tale of mechanical woe is I was just minding my business Monday night going for some food and in high gear, I was getting a surge. I keep driving to determine where I wanted to eat and figure out what is going on. I finally get about 25 miles away from home before deciding that gut instinct of this E36 M3 is going to go bad fast is hitting. I turn around and book it back to the house, but not without having to stop once and there was no go, nor the "I would be shifting now but I won't" neutral until I back off the throttle....
Finally, I get home just in time to smell that awesome sauce of burnt up trans fluid. Great. Here I am still hungry and now with a broke down in the driveway vehicle. I grab the only car with plates and insurance, a 1965 fairlane ranch wagon, and embark on food foraging. When I am eating, I decide on a used trans at the local JY of all my possible choices. Of course, I have to be in Florida on Monday.... Of course when I want to leave it starts pouring rain. Great. Must be a sign I'm missing somewhere...
Next day, I put that bad boy on credit to the tune of $2500 and have to phone a friend to come pick it up as they won't deliver to a residence. Oh well typical Michigan weather with the rain and grey skies around and I have to make room for this thing in the only garage space available. I move crap out of the way just enough to squeeze this thing between the 7' wide garage door. Make it in and up on stands it goes. Yes, I do have a lift, but then I have to move way more E36 M3 than I want to do. I start taking everything needed off except for the exhaust. It's always a pita. This was no exception. One nut actually came home, none of the others did. Then I find a broken but not leaking manifold bolt, so removing the manifolds is out. Then it becomes an "awww fukit" moment, very Roadkill-esqe, with a sawsall to make a removable section. Of course made a mess with cutting a hole in the trans pan with the blade. Ooops. I eventually get to the point of it almost coming out, just have to undo the bellhousing bolts and some other miscellaneous things, but it's time for a nights slumber at this point...
Next day, couple hours later, the old one is out and the new is ready to go in. I have to break out a different set of jack stands as they go taller so I can slide the new trans in under the frame. Which then leads to an interesting predicament, how to get 250# of trans up 6" to place on the trans jack platform. Easy answer: very crucial balancing act on a ratchet strap using the crossmember bolts for the anchor points. But it goes on without much fanfare because I already lightened it 60# by removing the converter, which now has to go back in. No biggie, couple clicks and where lifting into place... couple bolts started and snug.... Ok converter is next. Wtf? It won't move at all. Well that's dandy. Undo the tightened bolts and lower... Yeah some dumbass didn't make sure the converter was in the pump and bound it up solid. Reinstall attempt, much better outcome with fingers crossed nothing is broke and goes smoothly from here on out. I don't know about smoothly, but at 130am, I called it quits for the day with only the transfer case and driveshafts largely to go. And why between two sealed units is a fiber gasket that's a dealer only item???? Thanks GM.
Now, it's the morning of day 3... scrap gasket material from transfer case and extension housing for 1.5hrs with a razor blade... Place transfer case on jack and again balance this 85# of bs into place. First up and back to clear the welded in crossmember then forward to engage the trans while holding the front driveshaft up to clear the sway bar as it doesn't come off the transfer case readily. But it all goes together smoothly from here on out. I still have to exhaust to fix... 2 stainless 2.5" band clamps from Napa and some grey high temp rtv fix the cut through exhaust pipe. By 330p, it's running and does some good garage shifts just to verify it should move again. So far I have 6 qts of dex6 and a gallon of tractor fluid in it and it's close enough for a drive. Rather uneventful drive otherwise except I hate how it shifts because it's stock. Pull in the drive, check the level, still need another quart. Fill it, in the crosshatch, we good!
Now, to get a nail fixed in the brand new tires at discount and I'm ready for Florida after a stop home in TN....
Pictures along the way:
10/14/21 5:31 p.m.
*Homer drool noises while looking at all of the corrosion-free fasteners*
Mr_Asa
Mr_Asa PowerDork
10/14/21 5:32 p.m.
Nothing stops the march to Florida
Ranger50
Ranger50 MegaDork
10/14/21 5:47 p.m.
In reply to Pete. (l33t FS) :
Move. laugh
10/14/21 5:53 p.m.
In reply to Ranger50 :
No.  cheeky  I like living where income is good and cost of living is low.
BlindPirate
BlindPirate Reader
10/14/21 6:00 p.m.
I like Avalanches. Always wanted one, except I would like a 2500. Really hard to find
rob_lewis
rob_lewis GRM+ Memberand UltraDork
10/14/21 6:01 p.m.
You’re a better man than I am, Gunga Din!
But seriously, congrats on getting it done.  While I'm sure it was a PIA, be proud of being able to get it knocked out.  I'd guess less than 10% of the population would have been able to.
-Rob
Shadeux
Shadeux GRM+ Memberand Dork
10/14/21 6:05 p.m.
2.5k for a used transmission?
I'm... clearly out of touch with prices.
rob_lewis
10/14/21 6:08 p.m.
I'm not saavy enough to tell by sight, but I think that's a 4L80 which are usually more expensive and, in the situation he was in, he had to take what was available immediately and, I assume, from a JY offering some type of warranty.
-Rob
Ranger50
Ranger50 MegaDork
10/14/21 6:13 p.m.
In reply to rob_lewis :
6L80e.
If it was a 4anything it would have been a grand cheaper and much easier.
What warranty? If it dies it dies. I may fix it again. I typically am the warranty.
Ranger50
Ranger50 MegaDork
10/14/21 6:17 p.m.
In reply to Shadeux :
2095 unit price, 300 core charge, 126? in sales tax.
Also 84k miles on it.
John Welsh
John Welsh Mod Squad
10/14/21 6:42 p.m.
Oy! Big job!
Well done!
Did you say Michigan?  Were you in Michigan doing this?
Datsun310Guy
Datsun310Guy MegaDork
10/14/21 6:46 p.m.
My tranny needed replacement on my 2016 Silverado.  I laid underneath it one night and looked at the parts I'd have to pull off.
Being busy at work I paid a shop $3500 to rebuild mine.
10/14/21 6:50 p.m.
Yup.
Prices for used stuff, pulled and even delivered, with a warranty, are like that.
An LQ9 dropout (iron 6 liter engine) was $5k a few years back.
Looking for a specific Honda 3.5l last month, we were getting quotes in the $6k range.
Ranger50
Ranger50 MegaDork
10/14/21 7:07 p.m.
In reply to John Welsh :
Yes John. By myself.
Thanks.
Shadeux
10/14/21 7:44 p.m.
Great berkeley! I'm going to keep my mouth closed regarding fixing car stuff. I'm clearly out of touch.
vwcorvette (Forum Supporter)
vwcorvette (Forum Supporter) GRM+ Memberand UberDork
10/15/21 12:37 p.m.
I like the exhaust solution. Band clamps. Never considered that.
Ranger50
Ranger50 MegaDork
10/15/21 1:33 p.m.
I did get to keep the clickie pen I signed the credit card slip with tho....
docwyte
docwyte PowerDork
10/15/21 2:52 p.m.
I'd have a hard time doing a job like that on jack stands while I had a lift right there in my garage....
Ranger50
Ranger50 MegaDork
10/15/21 6:01 p.m.
In reply to docwyte :
To use said lift would have required to move the Galaxie into middle stall of the main garage, then move the immovable in complete resto mode ranchero outside. I would have then had to back the Avalanche onto the lift and still maybe not have enough room to lift it because of the steel storage against the wall corner. Oh and all by myself. I guess I could have driven it in but I'm not a fan of engine side on the long asymmetrical arms.
Ranger50
Ranger50 MegaDork
10/17/21 6:51 p.m.
Update:
No issues to report at this time, 1500-ish miles in. Currently driving past/through Cordele GA without any known issues.
Only problem I have is I couldn't reset the adaptives. It shifts way too soft and slow.
7D8GvJWnsUU4Bfm9FQODmXcKOBBLqMX7xrH5sAqLkyg4aXILGT7TwCWwa4sN7GTJ
