digdug18
digdug18 HalfDork
7/16/10 3:28 a.m.
What is the difference between Megasquirt 1, 2, 3?
And why would I want one over the other? I've searched but cannot find a side by side comparison of all of them.
MadScientistMatt
MadScientistMatt Dork
7/16/10 7:32 a.m.
There's a huge comparison list here:
http://ms3efi.com/feature-xref.html
MS1 - fairly basic system, can run fuel and ignition on many cars though.
MS2 - faster processor, allowing for some better control tricks and more precise injector control. Also has a stepper idle control.
MS3 - can be built for 8 cylinder sequential fuel and coil on plug capability, and a lot of features you'd normally only find on very expensive ECUs. Also in very short supply at the moment.
MicroSquirt - tiny MS2 based setup, not sold as a kit. Designed to be extra rugged and originally intended for bikes, ATVs, etc, but also works pretty well for cars.
DIYPNP - a MicroSquirt Module based build it yourself system that can be set up to plug into many stock EFI harnesses.
digdug18
digdug18 HalfDork
7/16/10 9:00 p.m.
is sequential fueling best then?
93celicaGT2
93celicaGT2 SuperDork
7/16/10 11:06 p.m.
digdug18 wrote: is sequential fueling best then?
Do you like apples or oranges?
The short answer i guess could be "yes." The long answer is: You'd be extremely hard-pressed to see/feel/notice a difference between sequential and batch.
UWp2IMgKZr5eawMd6pMKzM8Tzs366BbebdGfbXk9aPhHzyKN7TJXMb3M0W2YJgPY
