codrus (Forum Supporter)
codrus (Forum Supporter) UltimaDork
12/31/24 4:34 p.m.
Pete. (l33t FS) said:
Somewhere I recall that only a small number of the threads are actually under any load, no matter how long the threads are.  (6 or 7 threads?)  It's something to do with how the externally threaded component stretches when loaded while the internally threaded component compresses very slightly.
This IS nice from a soft-failure point of view, as if those threads yield, the load passes to the next ones up the line, albeit with a lessening of load on the fastener.
I've read that for steel threads, I don't know if the same thing applies to aluminum.  The stiffness of the material is different, so perhaps it deforms a smaller amount over a longer distance?  Then again the stud is still steel and maybe taht's where most of the deformation happens.  I dunno, I'm not an ME. :)
One nice thing about having the stud come out the back of the nut is that it's a quick way to avoid having to count turns when you put the nut on to make sure you've got enough.
12/31/24 4:38 p.m.
And you can easily see when a stud is stretching.
HiFiGuy
HiFiGuy New Reader
1/1/25 11:12 p.m.
@David S. Wallens,
Although I'm a big supporter generally of BW, including with my wallet, I buy Flug nuts because I think the engineering is the best I've seen.  Core4 Motorsports has them.  Flugs are available in seven different options including HEX, 60 degree taper or R14  I also have their MSI press-in conversion hubs on my Spec E46/endurance car.
Andy Hollis
Andy Hollis
1/2/25 8:06 a.m.
HiFiGuy said:
@David S. Wallens,
Dammit...I did not need to know these existed.
But...$10 each?  Whoah.
fnBGmGF7CQlPtpipcesW5zTn6Bu91SUPSzsUltVCFJCHXHpGjw8QHpJAT3u00y4T
