camopaint0707
camopaint0707 HalfDork
2/26/24 2:57 p.m.
another issue is that tire shops are extremely hesitant to mount up used tires.  Which doesn't help the take off crowd.
rdcyclist
rdcyclist GRM+ Memberand HalfDork
2/26/24 3:12 p.m.
It is certainly a worthwhile investment when a friend gives you an ex-Dunlop Racing Corghi machine and another gives you a Snap-On hand powered balancer. The only problem is the amount of real estate they take up in the shop. Having a powered tire machine is priceless; the ability to replace tires whenever I want to is really great. I use the machines about every other month or so. If I start racing/auto-x again, that'll pick up.
I've kicked my own ass using manual machines and after my accident, would be a non-starter.
Apexcarver
Apexcarver MegaDork
2/26/24 6:21 p.m.
I will say that I have had a number of problems with tire shops not understanding performance tires.
  • Refusal to mount used tires
  • Refusal to mount brand new Hoosiers as they were "bald" (even though they still had stickers and were obviously brand new)
  • Insistence that my 200tw tires with 500 miles on them were bald (they were barely scrubbed in) and that they couldn't legally let me drive my car home from the shop. (I threatened to call police and thankfully one of the other techs overheard me getting very pissed, came over and hit guy I was talking to over the head)
And don't get me started on performance alignments...
Ranger50
Ranger50 MegaDork
2/26/24 7:38 p.m.
In reply to theruleslawyer :
Gaffer tape is a cloth based super sticky tape, think better than duct tape.
codrus (Forum Supporter)
2/26/24 7:52 p.m.
Yeah, gaffer tape is what stage crews use for taping down lighting cords and the like, it's pretty good about not leaving residue (at least in normal use cases -- for wheels the higher temperatures make it not quite so good at this), and the cloth backing is strong so it comes off in one piece.
The guys at the Hoosier truck like to use aluminum HVAC tape, but I hate that stuff because it breaks apart when you try to peel it off.
I generally go to a local tire store ("wheel works", it's a regional chain in the SF Bay Area).  They recognize me now (I go there a lot), so when I show up with oddball requests they've been pretty accomodating.  Stuff like checking the first instance of a new tire of wheel against a my NASA template before mounting the other three.  They've actually been willing to mount used Hoosiers for me as well.
There are a couple of local race shops that will mount tires, but the tire store is way more convenient.  They're cheaper, they get it done faster, and they're open 7 days a week.  The one downside is that Hoosiers like to spin on the rim and so really want to be mounted with minimal lube (dry is best).  The race shop will do that, but I haven't been able to talk wheel works into it yet. :)
theruleslawyer
theruleslawyer New Reader
2/26/24 11:26 p.m.
I used to work at a film school. ;) Like duct tape it can turn into a goopy mess with heat. It wouldn't be my goto tape for wheels based on my experience with it, but I've been wrong before.
JG Pasterjak
2/27/24 11:46 a.m.
Toyman! said:
Not having to deal with the stupid people who work at the average tire shop is worth substantially more than the price of the machines.
Why should I drive half way across town to deal with stupid people when I have plenty at home?
JG Pasterjak
2/27/24 11:52 a.m.
Concur.
I really like having so many of the big things in my shop on wheels, but I don't really see that as an option for the tire machines. I mean theoretically it could probably be done, but I think the kind of sleds you'd have to build to properly support and stabilize those machines (especially the balancer) would be pretty complex and you may as well just go get a 10 x 10 garden shed or somethign if you wanted them off the shop floor.
2/27/24 1:11 p.m.
It's better than duct tape but not perfect, yes.  Is there a better solution out there?
chandler
chandler MegaDork
2/27/24 1:25 p.m.
I've always used aluminum tape
Ive moved mine a number of time trying to find the best spot
sorry, my garage is never not a mess
Toyman!
2/27/24 2:12 p.m.
In reply to JG Pasterjak :
I think you could use a saw mobile base for the balancer. Unfortunately, the tire machine is way to heavy for one of those.
BORA PM-3550 Super-Duty All-Swivel Mobile Base
2/27/24 4:37 p.m.
The HVAC stuff?  It's no easier to get the adhesive residue off the wheel than it is with gaffer tape, and the aluminum foil doesn't have the strength to come off in a single piece.
Andy Hollis
Andy Hollis
2/27/24 4:37 p.m.
Since we are getting into the DIY details, here's some of my experience.
Best way to remove weights and residual goo/paper/foam ==> plastic "chisel" designed specifically for that job, assisted by 3M Adhesive Remover spray.  Works way better than anything else I've tried, especially Brakleen.
Pop the weights off, spray some 3M on it, and work the tool back and forth on edge first to form a slurry, then flat as a scoop.  Second pass spray is usually only for goo, no paper/foam.  Use a blue shop tool to clean that off. Two passes for each weight block.  Do it outside or in well ventilated area.  Use the non-VOC version.
Oh yeah, my guy Joe has one caveat...same as pro racing paddocks.  Wheels must be clean and weight/goo free.  So I'm quite practiced at that part.
StuntmanMike
StuntmanMike New Reader
3/4/24 12:25 p.m.
For covering weights, Gorilla tape works well for holding them on and holding up to heat. If the tires end up lasting a long time, the tape starts to deteriorate towards the end but still much better than regular duct tape, and bonus its black so matches my wheels
Andy Hollis
Andy Hollis
3/4/24 6:12 p.m.
This sounds like what Pirelli uses when mounting at pro races.  Definitely not aluminum tape, nor regular duct tape.
3/4/24 6:48 p.m.
FWIW, Gorilla tape is a specific brand of gaffer tape.
StuntmanMike
3/11/24 7:23 a.m.
i'm not sure its the same stuff, it has a slick finish like duct tape but thicker, and def leaves residue. A pain to take off really but holds well.
camopaint0707
9/18/24 7:40 a.m.
I went in for $500 with two friends on just a machine.  No balancer.  I'm glad you guys mentioned the time saved too.  I can get home from work at 3.  Swap out 4 tires and be done by 4.  And still have time to get dinner going for my wife.  Imagine if I had to go into town, drop off tires, pay $100, come back the next day.  The time is so overlooked.  Also your own machine allows you to experiment with setups, try to new things, run used tires more albiet that can be a bad thing.
jcc
jcc New Reader
1/12/25 11:26 p.m.
I would suggest buying the most capable/newest balancer you afford, that would last forever and not become obsolete in the foreseeable future and also buying a used working suitable affordable changer that you will likely never wear out, and can last 50? years with just occasional use would make the most sense for us weekend warriors. i personally would place more emphasis on the convenience of being able to do a 1?am tire swap then any ROI calcs, because I can always off load the equipment down the road.
jcc
jcc New Reader
1/12/25 11:37 p.m.
In reply to bearmtnmartin (Forum Supporter) :
I had a small fleet of semis and trailers, all air ride, I always balanced all our tires, as we were hauling concert audio equipment. Did it really matter, don't know, but for peace of mid and not having to explain when opening a road case for a concert that was starting six hours and having to explain why there is a pile of hardware sitting in the bottom of the case was a plus.
IndustryPartner
IndustryPartner GRM+ Memberand New Reader
1/13/25 10:07 a.m.
In reply to bearmtnmartin (Forum Supporter) : The first paragraph of this comment is 100% false. The complete opposite is true, most tires are not round from the factory, or do they come out of the mold 100% balanced, hence the yellow and or red dots on the tires. Matching them to a new wheel, which is not 100% balanced from the manufacturing process, is a critical and challenging step to an experienced person much less a novice. Good equipment coupled with experience makes for more longevity better wear on your oh so critical wheel and tire package.
Spearfishin
Spearfishin HalfDork
1/13/25 10:16 a.m.
In reply to IndustryPartner :
I always try to put the yellow dot on the valve stem and my requested weights from the balancer are all over the place. Sometimes, if I get distracted on 1 or 2 tires in a set of 4, I'll not remember to line up the yellow dot, and I'd say it's a coin toss on whether they take more weight, less weight, or about the same as the tires that I did remember to line them up.
I'll continue to [try to] do it, but it certainly doesn't seem to be a deal breaker if it's missed.
Stueck0514
Stueck0514 New Reader
3/28/25 1:16 p.m.
Balance mine every time they get mounted, and then once more about halfway through life. I drive a Miata though, and it is very susceptible to any kind of imbalance.
Also noticed no mention of Road Force balancing in the article, the local Mazda stealership does it for $25/wheel and it does get that last bit of shimmy out.
vJHTlnWgzBqgOMbfJQ2z2ePvnNLSpFoTxEovnFKjHjIexubi5ohIRxr4cePXmguW
