mtn
mtn MegaDork
11/2/09 7:14 p.m.
Its been happening for about a year now, the glove box won't always open. However, it could always be opened if I locked it, and opened it back up. Sometimes it would take a little bit of force, but it would always open. Today, I was trying to open it, and the latch just came off, the entire thing. Any ideas on how to get into it? I don't "need" to get into it, but I do need to get into it, its holding the insurance information, and my sunglasses.
carzan
carzan Dork
11/2/09 9:13 p.m.
Lol...I sold an E30 a couple of years ago that I never did get into the glovebox. I have no idea what was in there. Coulda been a million dollars for all I know.
mtn
mtn MegaDork
11/2/09 11:35 p.m.
Really? Nothing? I gotta figure that the GRM group would know some special trick to get into it.
7pilot
7pilot Reader
11/3/09 12:18 a.m.
In reply to mtn:
Look at the latch and you'll see a piece that is curved downwards from the right hand side to the left. Push the bottom end of it to the right .
m
mrhappy
mrhappy Dork
11/3/09 2:33 a.m.
Is the metal part still there? If it is put your knees on the lid and push up/forward into the dash (like your trying to close it) if its all gone reach toward the firewall and rip it out. This is about the only ways i have been able to get in to them. about 10-13 all together.
z31maniac
z31maniac MegaDork
11/3/09 7:00 a.m.
Search on R3V, common issue and a common fix.
DukeOfUndersteer
DukeOfUndersteer UltimaDork
11/3/09 8:16 a.m.
there is a glovebox in E30s????
16vCorey
16vCorey PowerDork
11/3/09 8:44 a.m.
There's two little pieces of plastic inside the latch that break in half. I took mine apart, used a tiny drill bit and some tiny screws from the inside of a VCR to put the pieces back together. I was afraid using glue would gum up the whole works. Anyway, mine wouldn't close half the time, but usually opened. Good luck!
rjones33
rjones33 New Reader
11/3/09 1:04 p.m.
I love this board. Comedy.
2002maniac
2002maniac Dork
11/3/09 2:05 p.m.
just stick your finger in and push the latch to the side while lifting the glovebox with yourother hand.
mtn
mtn MegaDork
11/3/09 2:53 p.m.
Okay, so a little more detail here. Here are the pictures I took. Sorry for the poor lighting and quality, I only have a cell phone camera. I have tried pushing that "J" hook, nothing happened.
This one is the broken latch, the backside
And this one is the latch ON the glovebox.
porksboy
porksboy SuperDork
11/3/09 8:13 p.m.
This is one where a shotgun IS the answer.
mtn
mtn MegaDork
11/3/09 8:31 p.m.
I'm thinkin that. Going to get a drill, drill through the plastic, and figure it out from there. Its clear I need a new latch anyways...
2002maniac
2002maniac Dork
11/3/09 9:11 p.m.
push the J hook to the right. HARDER.
it IS the latch
mtn
mtn MegaDork
11/3/09 9:34 p.m.
Okay, I'll give it a go tomorrow. I'm pushing to the right, correct?
RossD
RossD MegaDork
11/4/09 7:30 a.m.
I've never put gloves in a "glove box".
mtn
mtn MegaDork
11/4/09 11:04 a.m.
RossD wrote: I've never put gloves in a "glove box".
Never seen anyone do it until I met my girlfriend.
2002maniac
2002maniac Dork
11/4/09 1:02 p.m.
did you get it?
mtn
mtn MegaDork
11/4/09 1:30 p.m.
In reply to 2002maniac:
Haven't tried yet. I'm in college, the garage is 3 blocks away, and I'm in class until 6 tonight. I might have a chance at about 3PM.
mtn
mtn MegaDork
11/4/09 3:29 p.m.
Got into it. Thanks everybody for all the help
ralph
ralph New Reader
2/27/11 9:58 p.m.
It can happen that the J hook breaks off leaving the rest of the latch assembly in place. Lots of posts in various sites have lots of suggestions, none of which worked for me.
I ended up drilling out holes in the front of the latch and eventually breaking the plastic extrusions that held the pins for the latch pivot. Buy a replacement latch and look at it and you'll see that if you drill just near the top right and top left of the key cylinder you can drill through the extrusions and break them off. The front of the latch should come off then. At that point you should be able to use a screwdriver to push the remainder of the j-hook to the right and release the pawls holding the box up. Mine was broken off at the pivot and was very difficult to push hard enough to disengage, but it finally worked.
It might be better to drill in a little more to the ouside and down to get below the plastic extrusions and get a screwdriver in there to pry up and break them off. I eventually broke mine off by prying from the back of the latch but I think that's the hard way.
Use masking tape with rolled up paper or cardboard underneath to protect the glove box from slips with sharp objects or drill bits. Ralph.
Ian F
Ian F MegaDork
2/27/11 10:53 p.m.
When I bought my E30, the glove box latch was the same. A new latch assembly is available from Pelican.
plance1
plance1 SuperDork
2/28/11 12:26 a.m.
I had a similar problem, I broke the glove box on my volvo 940 trying to get my gun out. Now it just stays open.
motomoron
motomoron SuperDork
12/26/13 3:16 p.m.
plance1 wrote: I had a similar problem, I broke the glove box on my volvo 940 trying to get my gun out. Now it just stays open.
Note: Someone carried a gun in the glove box of a Volvo.
ssswitch
ssswitch Dork
12/26/13 3:20 p.m.
I guess you could say he left the safety on.
bgLZsLNlIYqovpySqO4mXVanHUoKDXzjoWFOXborkObbmEw3YWnlW853RhSPMSk9
