Assuming, dangerous I know, that the crankshaft position sensor is good have you also confirmed that the wire is also good?
Sounds like the signal isn't getting to the brain.
Have you called outfront? I've had oddball questions about stuff I didn't even buy from them and they always helped me
Back when I used to mess with Subarus more often bad crank position sensors were a frequent no-start culprit. Ojala is on the right track, methinks.
