yamaha
yamaha Dork
11/8/12 12:18 p.m.
Considering I've watched a flywheel break into 4 pieces, destroy the transmission, stick one piece in the pavement, and launch the other bits really high into the air(through the bodywork of the corvair) .....I don't think kevlar is the answer. Possibly Kevlar and some mild steel plate would work.....I'll bet you that 3/8" thick AR500 steel will contain a flywheel though.
We couldn't even dent that with even a 30-06 last weekend, but the 1/4 mild steel plate looked like swiss cheese.
Giant Purple Snorklewacker
11/8/12 12:18 p.m.
N Sperlo wrote: Really? Because I had this idea of that dull knife from the infomercial that squashes the tomato before the sharp one cuts it...
What? Nah, you probably work out. That stuff would bounce right off. It's only like 18000Gs.
Curmudgeon
Curmudgeon MegaDork
11/8/12 12:20 p.m.
This thread reminds me that I need to build one for the Jensenator. Per SCCA Solo rules, a Mod car running race slicks is required to have a scattershield spec'd (IIRC) at 1/4" aluminum or .120 steel and driveshaft loops. Reason for driveshaft loops:
That's the Jensenator's trans tunnel as it was when I got the car.
I will probably overbuild my scattershield. Having seen a Mustang which was cut nearly in half due to a flywheel explosion, I'm more inclined to err on the side of caution at the expense of a few pounds.
N Sperlo
N Sperlo PowerDork
11/8/12 12:20 p.m.
In reply to Giant Purple Snorklewacker:
You've been spying on my Hip Hop Abs workout blog again.
11/8/12 12:20 p.m.
yamaha wrote: Considering I've watched a flywheel break into 4 pieces, destroy the transmission, stick one piece in the pavement, and launch the other bits really high into the air(through the bodywork of the corvair) .....I don't think kevlar is the answer. Possibly Kevlar and some mild steel plate would work.....I'll bet you that 3/8" thick AR500 steel will contain a flywheel though. We couldn't even dent that with even a 30-06 last weekend, but the 1/4 mild steel plate looked like swiss cheese.
No kidding - I made some metal targets with 9/16 hot roll I had laying around and all a 30-06 does is clean the rust off it.
tuna55
tuna55 UberDork
11/8/12 12:27 p.m.
It was a few thousand horsepower more than we're talking about here, but I like to link this picture:
Sky_Render
Sky_Render HalfDork
11/8/12 1:15 p.m.
petegossett wrote: I seem to recall a story about the Pentagon coating their walls with Herculiner to reduce shrapnel in the event of future attacks, so that might be a nice light-weight improvement as well.
Truck bed liner, slightly modified, is used to "explosion-proof" things.
ClemSparks
ClemSparks PowerDork
11/8/12 1:41 p.m.
But in the application you need to be sure not to get any on your hootus.
I'm sure they have protective hootus suits for the contractors that did the Pentagon.
foxtrapper
foxtrapper PowerDork
11/8/12 1:59 p.m.
N Sperlo wrote: I'm just thinking back to how not-so-great the Vietnam flack jackets were...
Well that's to go with the "acceptable losses" M16A1.
An explosion blanket around a bell housing may well contain an exploding flywheel (though many times the blanket is too far rearwards to catch it). But that doesn't mean the tranny tunnel isn't going to get hammered.
11/8/12 2:09 p.m.
foxtrapper wrote: An explosion blanket around a bell housing may well contain an exploding flywheel (though many times the blanket is too far rearwards to catch it). But that doesn't mean the tranny tunnel isn't going to get hammered.
IDGAF about the tunnel as long as my lovely gams are unscathed.
bearmtnmartin
bearmtnmartin GRM+ Memberand Reader
11/8/12 7:37 p.m.
I went looking for an image of the kevlar saw pants I used to wear in the bush stopping a chain, but I found this instead and got sidetracked. It may be relevant anyway so I thought I should post it.
dculberson
dculberson SuperDork
11/8/12 7:49 p.m.
Wow, a CRT monitor, don't see those every day any more.
What, was the focal point of the picture something else?
Jaynen
Jaynen HalfDork
11/8/12 11:02 p.m.
Did you say something?
chaparral
chaparral GRM+ Memberand HalfDork
11/8/12 11:37 p.m.
I'd suggest using the scattershields as bracing.
Use a .120 wall square tube instead of a .250 sheet - remember, it has to go through both sides of the tube.
agREKLv90pPzC6nbPr3fUMP8cxfAdwNV2dL1VApPrFzmLD1xxUeKKvCQSIOktBLT
