JacktheRiffer
JacktheRiffer New Reader
5/29/14 5:33 p.m.
Im trying to figure out if I should buy an engine hoist to both remove a 240z engine and install a turbo l28. My grandpa has a chain hoist and Ill be storing and working on the car there. Would the chain hoist be sufficient to lift the engine?
DrBoost
DrBoost PowerDork
5/29/14 5:40 p.m.
You mean one of those big A-frame things? I suspect it'll be fine.
Will it be able to roll in and out of the way with jack stands there?
JacktheRiffer
5/29/14 6:04 p.m.
The hoist is mounted to the wall of his shop. The car will roll in.
bgkast
bgkast GRM+ Memberand SuperDork
5/29/14 7:01 p.m.
$190:
Apexcarver
Apexcarver PowerDork
5/29/14 7:32 p.m.
I used a chain hoist over a steel i-beam in my shop to do my miata engine. As long as what the hoist is tied to can take the weight and the hoist itself is rated, its no problem.
That said, you do have a bit more up and down off the stands doing it that way because you have to roll the car out from under the motor rather than rolling the hoist away from the car.
Completely doable though. Been there done that, my dad did a mustang that way when I was a wee lad as well.
Apexcarver
5/29/14 7:34 p.m.
bgkast wrote: $190:
$50 at Harbor Freight
I cant remember if mine is the 1 ton or two ton... But one of those is what I have and used for the miata.
calteg
calteg HalfDork
5/29/14 7:36 p.m.
Harbor Freight has a...generous...return policy.
Just sayin'
JacktheRiffer
5/29/14 7:52 p.m.
May go ahead and buy the hoist...could come in handy down the road
Ojala
Ojala GRM+ Memberand HalfDork
5/29/14 8:01 p.m.
Parts store near me "rents" engine hoists for free.
I have pulled many engines with the tree behind my parents house and a chain. Either way you will be just fine.
Don't do like I did and attach the chain to the back of a truck and use the tree limb as a pulley to lift the engine.
ross2004
ross2004 New Reader
5/29/14 8:10 p.m.
bearmtnmartin
bearmtnmartin GRM+ Memberand Dork
5/29/14 8:57 p.m.
I watched six husky guys pull a small block out of a pickup once..
tuna55
tuna55 UltimaDork
5/29/14 9:11 p.m.
My 17 year old self along with a buddy and his Dad pulled a complete 2.8 out of a Camaro with our arms. A chain hoist will probably be fine, though.
5RwuPPPRW6jXtRWAl9RxHp8ycNwCsElih0hQErGWFvJgsIEZTCGQawDEv0gYjGU2
