the fiat 128 engine should hold up fine. Aluminum head on an iron block. Just do not try for the 100hp shot
mad_machine wrote: the fiat 128 engine should hold up fine. Aluminum head on an iron block. Just do not try for the 100hp shot
Agreed, especially a semi stock motor as they aren't very high compression.
And if/when you blow it up, give me a holler, I have a few spares ;)
I have 20psi on a stock 1.1L. So I dont see why you cant run a 50 to 100 shot.On a 1.3L I trust your using FelPro head gasket. # 21195 PT-2
93EXCivic wrote: In reply to GVX19: What does that head gasket do?
Seal the head to the block usually
aussiesmg wrote:93EXCivic wrote: In reply to GVX19: What does that head gasket do?Seal the head to the block usually![]()
but that's not important right now
I did it to my Yugo with a 1.3L EFI. Dry shot. 75 hp, I think.
Didn't hurt, but didn't help a lot either.
I'll give you 5 dollars if you swear you'll never say/type "NOS" again.
It's (nitrous oxide, that is...not "Nitrous Ox Side") an easy, cheap, "afternoon project" way to make power with a motor you don't give a E36 M3 about. Use common sense. Err on the side of too much fuel. Monitor AFR if possible. If not, make a pass, pull a couple plugs, adjust jets accordingly. Have fun, use a bottle warmer to keep the pressure ~1000 PSI. Speaking of 1000 PSI, carry that bottle like a baby. Seriously.
If it doesn't help a lot on a motor with less than 100hp, you've berkeleyed something up. We gained 45 hp on the first challenge crx; 50% increase over stock. You'll feel that. Lot of trial and error with jets though.
poopshovel wrote: I'll give you 5 dollars if you swear you'll never say/type "NOS" again.
Excellent, thank you Poopshovel.
tuna55 wrote:poopshovel wrote: I'll give you 5 dollars if you swear you'll never say/type "NOS" again.Excellent, thank you Poopshovel.
What...it's not NAAAAAWS Yo! and said with your hat at a funny angle while granny shifting your 28 speed Hon-derrr?
I'm shattered......
In reply to yamaha:
owning an old Fiat, when I read NOS I thought New Old Stock, and then for some reason I remembered there's a new Fiat, and thought we were about to see some NOx on a new Abarth, but I'll take anything I can get, so please, continue
RoadRaceDart wrote:tuna55 wrote:What...it's not NAAAAAWS Yo! and said with your hat at a funny angle while granny shifting your 28 speed Hon-derrr? I'm shattered......poopshovel wrote: I'll give you 5 dollars if you swear you'll never say/type "NOS" again.Excellent, thank you Poopshovel.![]()
But Dom doesn't use Nawz!
poopshovel wrote: I'll give you 5 dollars if you swear you'll never say/type "NOS" again. It's (nitrous oxide, that is...not "Nitrous Ox Side") an easy, cheap, "afternoon project" way to make power with a motor you don't give a E36 M3 about. Use common sense. Err on the side of too much fuel. Monitor AFR if possible. If not, make a pass, pull a couple plugs, adjust jets accordingly. Have fun, use a bottle warmer to keep the pressure ~1000 PSI. Speaking of 1000 PSI, carry that bottle like a baby. Seriously. If it doesn't help a lot on a motor with less than 100hp, you've berkeleyed something up. We gained 45 hp on the first challenge crx; 50% increase over stock. You'll feel that.Lot of trial and error with jets though.
ACTUALLY, when referred to as NOS, it stands for Nitrous Oxide System.
so, he is using the term wrong.. like Kleenex.
JThw8 wrote:Raze wrote: thought we were about to see some NOx on a new Abarth,Don't tempt me....
Doo eeeet.
