My birthday is coming up and i decided to gift myself a MIG welding unit. My price cap is pretty solid at $300. Must run on house current so no 220V systems. Must be a true MIG unit with gas setup...no flux core. Lastly no cheapo Harbor Freight units.
What units would you advise.
Annnnndddd go.
http://wio.ru/korea/mig15.jpg
Sorry, couldn't resist.
They always say when it comes to MiGs, buy the best you can afford or you'll end up regretting it.
I'd still be careful with a MiG, no matter how new it is. One wrong move, and
.jpg)
because welding with fire
I use a cheapo CH unit from Lowes. It gets the job done. It came with the regulator and hoses for gas, but I have never used them. Flux wire does everything I need it to. It was $280, but that was ten years ago.
CarKid said:
Find me a MIG.
http://www.controller.com/listingsdetail/aircraft-for-sale/MIKOYAN-MIG-21-UM/1967-MIKOYAN-MIG-21-UM/1163877.htm
That was tooo easy, what else ya got?
In reply to slantvaliant:
That Eastwood is probably the best you'll find new for anywhere close to $300. I'm not 100% sold on them yet. I did a lot of reading on them after someone mentioned them in one of the other recent welder threads.
Tractor Supply has the Hobart 125 for $350, but you're stuck with only 4 voltage settings with it.
For another $140 you can get a reconditioned Hobart 140 from Toolking Pretty much the best deal you're going to find "new," and well worth it in my opinion.
Is you're $300 budget including bottle, hood, tools, etc.? Or just for the welder? If you want it all for less than $300 then you're stuck with the cheapest of the cheap chi-com HF units or the Craig's List score of the decade.
YaNi
Reader
7/27/11 10:34 a.m.
- Lee
That's like welding with a coat hanger, jumper cables, and a car battery. I bought a Horrible Freight 220v MIG when I was a broke kolledge student, and its their typical chicom garbage. My welds look 100x nicer with my friends 120v Lincoln and it doesn't spit and sputter before it creates an arc.
I was/am in no way recommending a HF or any other cheap POS "welder." OP stated he didn't want one, I was letting him know he is likely to have no other choice with such a limited budget.
cwh
SuperDork
7/27/11 11:28 a.m.
The refurb Hobart is my suggestion. Good quality, parts available, good price.
For another $140 you can get a reconditioned Hobart 140 from [Toolking](http://www.toolking.com/hobart-500500a-factory-reconditioned-handler-140-mig-flux-cored-welder-a-stock) Pretty much the best deal you're going to find "new," and well worth it in my opinion.
- Lee
Ill look at both of those. Seem like good deals
That Hobart unit looks nice but its $450 which wil have to be ok.
BUT for $450 what else can i buy. Same guidelines but now a 450$ price cap
Taiden
HalfDork
8/2/11 7:45 p.m.
Personally I would wait for a used Lincoln 140C on craigslist.
I don't think your going to find anything as "new" as that Hobart for that kind of money.
Craigslist/fleabay are pretty much your only other options.
One of my at least bi-weekly Craig's List searches is a Miller 211. That's what I've got my sites on, but used it's still $700+ I haven't found that smoking deal yet.
I'd guess used you MIGHT get a Miller 180, Lincoln 180C, Hobart 185/187 for that kind of money. You could for sure get a used Lincoln 140C or Hobart 140 for that or less, maybe even a Miller 140.
It's been said a hundred times before, just pick you're favorite color.
Taiden
HalfDork
8/2/11 9:05 p.m.
I dream of the day that I find a Millermatic 211 for $400
It would make a fantastic complement to my $450 Maxstar 150 STL
Glad I found this! Looking for one myself, had a CH one, loaned it out to 2 different people, not sure which one it really crapped out on, never really got the chance to play with it
Looking for a replacement to start learning with, was about to go to HF this weekend, glad now I looked at this. Saw the Hobart 125 & the 140 on Tractor Supply, they have the 140 new for $499, figure it's worth the $10 extra over the refurb price. The 140 only has 4 voltage settings per the TS website, that was mentioned as a downside for the 125. I never expect to be a master welder, but I would like to be able to go out to the shop, fix my trailer/tractor/go nuts & weld crap together, so is that a serious drawback, or just for the guys who weld daily?
I haven't found the fixed voltage settings to be a limitation, FWIW.
I don't think they're a limitation if you are an experienced welder (that can adjust speed, and wire feed to compensate for "middle settings"). For less experienced welders I think it is nice to have a more "exact setting" to give you the best chance for a good weld.
I think this is one of the reasons I think TIG is easier than mig for the inexperienced welder. Much more control, much slower, fewer fireworks.
Could be. FWIW, 95% of the time all I do is set the machine to what the chart shows, and then hit the trigger. It's rare that I ever touch the knobs beyond that.
Second recommendation for Eastwood 135
Taiden
HalfDork
8/3/11 2:45 p.m.
The 4 settings for heat shouldn't stop you from welding anything.
But infinite adjustability makes for a better welding experience.
