alfadriver wrote:
Lewis wasn't too aggressive, he just chose the wrong side.
And in the post race interviews, Lewis made the comment that he could have gone left or right, but the right side had much more space, so that's the one he chose. Note below how much space is on the right v. the left when Lewis starts to move. Plus, being a seasoned driver, Lewis probably also knows that being on Nico's right, even if Nico picks speed back up, will put him on the inside of the next turn.
Further (to add fuel to the discussion), in the above Sky video, Lewis makes the move to the right. Nico moves over to defend. There is a critical point where Lewis's front wheel is even with Nico's rear.
At that point, his right side tires are off the track, but the left would still give him enough traction to continue. If Nico stays there, both drivers come out OK just lots of puckering. If Lewis jumps on the brakes, however, the car will pull to the left and INTO Nico because the right side tires have no traction. Absolutely causing a wreck. Nico continues to move over, so Lewis is forced to keep moving to the right to avoid a collision. It's possible, Lewis could have kept is straight, gotten back on the track and resumed racing. BUT, that grass is way too tall, he loses traction, so he continues at the same speed, Nico's now turning, so he's losing speed and Lewis's car catches Nico and the wreck occurs.
Lewis took what he thought was an obvious pass. Nico defended and continued to move, putting Lewis in the grass. No harm no foul at that point. It happens all the time in F1 where a defender will move an aggressor over right up to a wall (like coming down the straight). Since those moves are on asphalt, both drivers can continue. If the defending driver continues to push, the aggressor will get shoved into the wall and most likely collect the defender. In this case, there was plenty of room, but the zero traction on grass is why it didn't work the same.
I still agree it was a racing incident especially since both drivers suffered from it.
-Rob
