SunbeamFanatic
SunbeamFanatic New Reader
12/15/18 5:50 a.m.
Hi All,
I've been doing some research and would seem the complete front suspension from a Crown Vic may offer everything I need; upper and lower wishbones, spindles with forward facing steering arms, steering rack in front of cross member, coil-over shocks etc.
Has anyone used this set up? Any pointers as I would probably need to narrow it a bit?
jmc14
jmc14 Reader
12/15/18 6:38 a.m.
I use C4 Corvette suspension for a number of my builds with good results.  The parts are reasonably priced here and available.
Good luck with your build. Nice start!
SunbeamFanatic
12/16/18 12:11 a.m.
I've looked at the C4 front suspension and it looks like a really nice set up.
It seems like it's all aluminium, is that right? If it is do you think it will hold up an iron block LQ4 in a steel body? As the Corvette it was designed for is fibreglass so I'm guessing much lighter.
Many thanks.
ecpKpGH6sZlcYGufPrYRyet2Rw4XKmvURWP94f53NY2kQdlVwim89fAIangII8il
