9/21/22 8:06 p.m.
Rust has taken some of the inner structure of my replacement fender. The structure of the mangled federal is pristine. I'm POR15ing the rust. It hasn't affected the integrity of the fender. It looks like all the rusty metal did was hold a peice of foam to promote more rust.
Do I POR15 and send it, or pop rivet the good metal to the new fender? ( I have no welder)
Run_Away
Run_Away GRM+ Memberand Dork
9/21/22 8:44 p.m.
I'd try to pop rivet some new metal in there. Is there enough room for a rivet between the inner structure and the exterior skin?
9/21/22 9:10 p.m.
I'm thinking of Zing the new fender Metal back, and then riveting. If it ends up wonky,  I'll just drill out the rivets.
Purple Frog (Forum Supporter)
Purple Frog (Forum Supporter) GRM+ Memberand HalfDork
9/21/22 9:12 p.m.
Are you on your way to Pebble Beach next year?  POR15 and go forward.
VolvoHeretic
VolvoHeretic GRM+ Memberand HalfDork
9/21/22 9:16 p.m.
How clean does it have to be to apply POR15?
barefootcyborg5000
barefootcyborg5000 PowerDork
9/21/22 9:20 p.m.
Pretty sure Bob has a fender he'd sell you on the cheap.
Streetwiseguy MegaDork
9/21/22 9:26 p.m.
Por it up and bolt it on.  You won't make it any straighter, and it's just there to keep the bottom a bit straighter.
9/21/22 9:38 p.m.
It's an $1,800 truck. I'm not sure why I'm giving this much E36 M3. Thanks guys.
9/21/22 9:44 p.m.
As I understand it, get rid of the loose scale, and it's good. I'm going to read the directions, of course.
adam525i
adam525i GRM+ Memberand Dork
9/21/22 10:06 p.m.
I'd wire wheel and hit it with the metal prep or ospho before moving onto the POR-15/rust paint etc.
bXVWUck7s7LZ8P3vJkteYb1DOEaFOrj9BdQjCzWEJD4VIQcEfC083JPvwPJBMvVo
