whenry
whenry HalfDork
11/21/13 7:11 a.m.
A lot of spring? You may not be compressing the spring enough with the weight of the car. Or the spring may not be tall enough. You may need the helper springs to "load" the suspension.
Swank Force One
Swank Force One MegaDork
11/21/13 9:00 a.m.
whenry wrote: A lot of spring? You may not be compressing the spring enough with the weight of the car. Or the spring may not be tall enough. You may need the helper springs to "load" the suspension.
Possible on all counts. They are off the shelf lengths, but 550lb in front, 500lb in rear. No helper springs.
Car weighed in at 2600lbs last year, it's probably around 2550 now. Figure a 63/47 f/r split.
pres589
pres589 SuperDork
11/21/13 9:01 a.m.
63/37
Swank Force One
11/21/13 9:02 a.m.
Yeah, that.
pres589
pres589 SuperDork
11/21/13 9:13 a.m.
I remember using a jack to lift the driver's side of my 626 off the ground to do a front/back tire rotation (factory directional wheels, whee) and the jack had to be pretty far forward to balance the car. I doubt the MX-6 is much different.
Swank Force One
11/21/13 9:14 a.m.
It's not...
Here's my numbers from last year.
Bobzilla
Bobzilla PowerDork
11/21/13 10:08 a.m.
pres589 wrote: 63/37
Ah hell nah... this thing is 110% man.
Swank Force One
11/21/13 10:26 a.m.
I go hard like that.
evildky
evildky Dork
11/21/13 2:19 p.m.
You need some zero rates to fill the space or shorter struts
CDxCI7vU3dXZDuiEdsedkcIrEGQEa9Z7knp4JRVPuB9ykIjc4sVbzEnnMTega96v
