I think it's from a Ford 2.3 and a four-speed. Not a very good picture, but it wouldn't be as much of a challenge if it was...
This is definitely a Ford 4 cyl bell housing. Either a 2.3 or 2.0 - I believe both are the same.
Yours is similar but different. Is there a part number?
L5wolvesf said:This is definitely a Ford 4 cyl bell housing. Either a 2.3 or 2.0 - I believe both are the same.
2.3 has the two upper bolts higher up.
What is weird is it LOOKS like the 2.3 and 2.5 engine blocks had the lower position top bolts as used in the 2.0, but they only ever used the 2.3-specific bellhousing in practice.
This is the same company that made all 429/460 from 1968 to 1997 (?) with the bellhousing pattern for the MEL 430/462 engines, but never actually used those locations either.
I second 4 cylinder Ford. The clutch fork and starter location. The casting style looks early 1960s English, so could be as small as a 998 CC sports racer or front engine F Junior. The Ford part is iron. What alloy is yours? it kinda looks magnesium.
In reply to TurnerX19 :
It's definitely from a Lima (2.3) engined car per the upper bolts. Or possibly a Cologne V6. The confusing part to me is the transmission pattern. It is rotated, and the pattern is completely unfamiliar. Could that be from a Capri and one of its oddball (for the US) transmissions?
...or a mid engine transmission? Very curious.
Pete. (l33t FS) said:In reply to TurnerX19 :
It's definitely from a Lima (2.3) engined car per the upper bolts. The confusing part to me is the transmission pattern. It is rotated, and the pattern is completely unfamiliar. Could that be from a Capri and one of its oddball (for the US) transmissions?
I was thinking merkur t9.
In reply to Pete. (l33t FS) :
The trans end doesn't match any transaxle I know, it looks front engine. I caught the tilt too, which made me think Lola Mk2, as that had a lay over non crossflow 998. There were a few other front engine Ford juniors too. Do we know for sure that it is tall enough for the Lima? I can't tell in the photo without a ruler. I can't think of many front engine Ford cars that would use something non Ford. Aftermarket aluminium replicas of the Ford part were available, I installed one on an Elan, which is the smaller bellhousing pattern.
Since I took pics I figured I would post my BH on eBay, While there I came across 2 that look very similar. But the tilted trans pattern is not there.
Ford 460 Big Block Bell Housing
In reply to L5wolvesf :
You still haven't said what material it is. It looks like black anodized magnesium on the trans face.
TurnerX19 said:In reply to stan :
What material is this???
I was thinking (assuming) it was aluminum, but now I'm not sure. It seems fairly light. What would be the tell if it is magnesium?
In reply to stan :
If it melts, it's aluminum if set of fire. If it makes the fire bigger, it's magnesium.
In reply to stan :
In an inconspicuous place take a sharp knife and scrape a few shavings onto a stone or pocelaine plate. Then ignite. Aluminum will be hard to ignite, Mag will burn easily and very white hot. If you get aluminum to burn you can extinguish it. Mag pretty much has to burn out. Also all of the mag alloys will cut well with a stiffer feel than cast aluminum. Scrub it up and post more pics, especially dimensions across the center top to bottom. All of the Ford brand bell housings are iron, although the little ones are so thin they are not heavy. We saved 4.5 pounds with an aluminium one one the lightweight Elan I built. Not a bargain for $1000. US in 1991!
Cool. I'll give that a go tomorrow. Thanks.
