Woody (Forum Supportum)
10/25/21 8:18 p.m.
Has anyone here C-notched or Z’d a hot rod frame?
I have some ideas for a potential project, but I'd like to see how others have approached this idea first.
SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) UberDork
10/25/21 8:46 p.m.
I've Z'd an F-100 front clip.
I've C-notched a C10 and a D21.
I've step-notched another C10.
There are lots of online examples....
bgkast
bgkast GRM+ Memberand PowerDork
10/25/21 8:47 p.m.
daeman
daeman Dork
10/26/21 4:50 a.m.
Check out minitruck builds, very common proceedure in that scene.
SVreX (Forum Supporter)
SVreX (Forum Supporter) MegaDork
10/26/21 6:03 a.m.
Ok, help me out. These are abbreviations I am not familiar with.
What is C-notching?  What is Z-d?
10/26/21 6:10 a.m.
In reply to SkinnyG (Forum Supporter) :
I guess Step Notching is the idea that I'm thinking about, but I didn't know the term. I was picturing angles not curves though.
Imagine a six inch tall frame with a six inch tall box section welded to the top of it with wide A-shaped plates welded to the outside, and then cut out below the crossbar of the A.
10/26/21 6:15 a.m.
In reply to SVreX (Forum Supporter) :
They are methods to lower hotrods.
Imaging the back half of a truck with a straight frame. For a C-notch, you weld on reinforcement plates and then cut a C-shaped notch that allows the rear axle to move up "into" the frame when the suspension is compressed. It gives you a little more upward travel.
With Z-ing, you cut that frame in half and then one half is welded back on a few inches higher, with reinforcement. The results are similar, but less elegant and probably weaker in most cases, expecially with an extreme drop.
10/26/21 6:16 a.m.
Example: Z'd front and rear
10/26/21 6:20 a.m.
In reply to Woody (Forum Supportum) :
Gotcha. Thanks.
I knew the method, just didn't know the name
Mr_Asa
Mr_Asa PowerDork
10/26/21 7:11 a.m.
There was (I think) a parking lot build with a Chevy truck that had that before the parking lot.
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
10/26/21 7:14 a.m.
It's the same method you use to run 6" drain pipes right through 2x10 floor joists...........laugh
bobzilla
bobzilla MegaDork
10/26/21 7:34 a.m.
Brad was z-notched to keep the front steering geometry close to stock.
10/26/21 7:50 a.m.
Plumbers are the bane of my existence.
10/26/21 9:38 a.m.
You bought that T didn't you? Guess that pic I posted had more effect than I expected.
10/26/21 9:42 a.m.
An angular step notch is more common, a curved step notch like I did is stronger.
A c-notch is profoundly weaker than the original frame; you really want to maintain original frame thickness over the notch. But, what are your options?
If you're doing an old-school hotrod, I'd be Z'ing all the way, that's probably what you want to be doing. Make sure you use fish plates to reinforce the weld.
10/26/21 10:04 a.m.
In reply to Appleseed :
I did not.
But there's this truck...
10/26/21 1:11 p.m.
What I would like to do is remove the giant rear spring pack, shorten the wheelbase and mount a lighter duty rear axle with more room to travel upward.
10/27/21 7:06 p.m.
Did you buy those step plates or did you make them yourself?
10/27/21 9:33 p.m.
I made them myself.  Cardstock pattern, 3/16" plate, plasma cutter, freehand.
XbS5IV8Ugucume965YdvdlSMB4zIjyqmqDiFA3B3tNKIilJqVN93ep0HXB2rDoxz
