So I drove my mk1 diesel away from home. Maiden voyage. Battery is completely dead.
This car has a hacked minimal harness to make it run, no factory wiring, and no factory cluster. The alternator does not self excite, which I found out the hard way.
How can I rig this up to get home?
Can I put 12V jumper right to B+?
Do I just tap it then remove it?
Etc.
Thanks!
IIRC, factory wiring has an idiot light between switched 12v hot and the D+ terminal, which is what excites the alternator.
Well, finally got it jump started. Turns out, tapping 12V to the D+ terminal once it was running kicked in the alternator to charge. So far so good.
