Because the factory part seems to be particularly failure prone, and because Honda dealers want $33 or more for a new on, I'm looking for an aftermarket alternative to the OEM replacement thermostat on my Honda VFR. I know, this is a car site, but this is also the best car repair & mod site that I know of and this sort of thing should be right up the GRM Forum's street.
What some 5th & 6th gen VFR owners have done is get the Stant replacement for Honda cars that has been installed seemingly forever, Stant p/n 13878 which gets installed in things like 1989 Accords to 2002 Civics to all sorts of things in-between and beyond. The problem is, it has to be ground down "about 1/4th of an inch" around the circumference of the thermostat, otherwise it doesn't fit into the VFR's stock location. What I'd like to find is a better fitting t-stat. My problem is, I don't know how to go about it without removing my existing t-stat and going through every single boxed thermostat on the shelf of whatever auto parts store will let me.
The diameter of the VFR's thermostat has been measured at 1.730 inches, with a total overall height of 2.251 inches. Is there a guide somewhere that I could use to look this up?
The common failure mode with these things seems to be sticking wide open 100% of the time, and it seems to be a common issue starting around 16k miles no matter how old the bike is. I'd like to get past that by using a quality aftermarket item that I don't have to grind on before installation. Any information on how to find this part on my own or if someone has one in mind that should drop in, please let me know.
Wonkothesane wrote: As stupid as it sounds, have you called the manufacturer about it (in this case stant)? They generally have a good idea of what they sell, so if you give them the dimensions you're after they should be able to get you hooked up with a part number. That's how I would go about it. Cheers!
Can try Stant, they were contacted about this once before, although I don't think with dimension information. Instead it was about an exact replacement using the model, to which the answer was basically "we don't serve the motorcycle market".
I don't have to use a Stant, they're just one of the more popular options when going to an aftermarket replacement source for a thermostat. Is there any other "big" company that seems worth trying? Will try and find Stant's customer service information in the meantime.
I did googling and found nothing until I took your 1.730" and turned it into 44mm. This site might help although it is in Australia.
TJ wrote: I did googling and found nothing until I took your 1.730" and turned it into 44mm. This site might help although it is in Australia. link
Oh snap. This is what I get for not keeping in mind the USA is the only major market that is still using inches. I'll have to do some double checking but it looks like the thermostat used by VW Group in such motors as the 2.8 VR6 are 44mm.
Thanks for the help!
