TDC, CKP(crank), and CMP(cam) if it's OBD1
TDC and CMP of it's OBD2
If it's leaking internally I don't think that seal is a replaceable part.
Run_Away wrote: TDC, CKP(crank), and CMP(cam) if it's OBD1
That should be INSIDE the distributor, not under it.
TDC and CMP of it's OBD2 If it's leaking internally I don't think that seal is a replaceable part.
OBD2 cars have the TDC and CMP sensors on the crank.
Yes, the cam seals in the distributors are replaceable.
Sounds like a leaking Coolant temp sensor or something else. Check Majestic Honda's excellent parts website for an exact detail of what it is. www.hondaautomotiveparts.com
Sure that leak isn't the distributor itself? They're pretty notorious for oil leaks. I think the water temperature sender is under there on an OBD0 car?
