dean1484
12/24/17 10:13 a.m.
The horn in my Denali is less than inspiring. I want to replace it with something that will get the attention of those that for some reason can not see a full size GMC truck.
I would like a basic bolt in. I don’t mind adding relays and running better power but no air compressors or anything like that.
I am looking for suggestions.  Can be new aftermarket or used form the junkyard. Either is ok.
Dirtydog
Dirtydog GRM+ Memberand Reader
12/24/17 10:17 a.m.
Older Cadillac horns. Loud  and distinctive. Should be plug and play.
wheelsmithy
wheelsmithy GRM+ Memberand Dork
12/24/17 10:35 a.m.
Chrysler mini vans have surprisingly aggressive dual tone horns, and are plentiful at the pull-a-part.
John Welsh
John Welsh Mod Squad
12/24/17 10:55 a.m.
Cadillac 4 note!
Off ebay a set should run you $50-$75 but amazing! Only slight fab work needed to mount.
Search "Cadillac 4 note" on YouTube for examples.
Jumper K Balls
Jumper K Balls PowerDork
12/24/17 11:01 a.m.
Fiamm twin tones are under $50 and will get a lot of attention.
12/24/17 11:28 a.m.
A couple of locomotive air horns popped up on my local govdeals site.
EastCoastMojo
12/24/17 11:33 a.m.
If they can't see a full size truck, nothing short of a compressor powered train horn will do. laugh
Woody
Woody GRM+ Memberand MegaDork
12/24/17 11:45 a.m.
I prefer the Fiamms that Jumper K. Balls listed, but Fiamm also makes a compact unit that's easier to install. I put one in my WRX.
I've used these Hellas too. They sound awful, but damn are they loud!
Jerry
Jerry UberDork
12/24/17 1:40 p.m.
I have the Hella's on the WRX, but when I was looking for Fiat choices a number of people on the forums have this guy:
Daylan C
Daylan C SuperDork
12/24/17 1:43 p.m.
First thing this thread made me think of was Hella Supertones in the grill of a Subaru.
I have no actual experience with Hella Supertones or Subarus.
Edit: I think I need 4 notes on my everything now.
spandak
spandak New Reader
12/24/17 1:46 p.m.
Fiamm freeway blasters, both the high and low. They look just like most OEM horns, will bolt up with no mods and the stock location and are noticeably louder. I added just the low note on my Mazda to supplement the single high note and people can actually hear me now.
12/24/17 5:15 p.m.
+1. I have them to replace the non-op horns that were on my disco. The sound also surprises and perhaps confuses people, so it gets their attention
Knurled.
12/24/17 5:25 p.m.
I want one of those cow horns they used to sell in J.C Whitney catalogs, where you didn't have a button, you had a lever, and you could work the lever to make any noise from gentle lowing to full on "I am about to wreck you" enraged bull.
I want it to mess with corner workers when I rallycross.
einy
einy HalfDork
12/24/17 5:36 p.m.
+2 ... have them on the Exocet, and they have saved my bacon more than once already.
codrus
12/24/17 6:15 p.m.
My experience with the air horns like that (not sure if the same brand) is that they last about a year and then the compressor stops working.
Floating Doc
Floating Doc GRM+ Memberand Reader
12/24/17 9:20 p.m.
I have a set of Fiamms in my 88 Silverado. I bought them for about $12 on clearance from the website, I guess no one wanted a set molded with purple plastic (the bells on the horns and the base of the compressor). I didn't like the purple color either, but some plastic friendly black spray paint took care of that. They're loud, and have been in the truck for about three years.
I do make a habit of blowing the horn every week or two, since it has a component with moving parts. Between my home and work, I travel through a wildlife management area. If there's no cars nearby, a brief sounding of the horn isn't likely to bother anyone.
I've been happy with them, and would install a set again.
Patrick
12/25/17 7:52 a.m.
Which of those that will work on a wrx don’t make the “hi i just hit the horn on my cute little geo metro” sound like my factory horns?
NdEIiqn8c5keiCxDk1makyxWOGiRAW2xCejtQd0RNpKMeDdb0gR461td49emzn83
