Streetwiseguy Dork
8/31/11 5:59 p.m.
would a guy need to fit an LS1 in a Subaru SVX?
(Waiting patiently for hotlinked pics and build threads)
DoctorBlade
DoctorBlade Dork
8/31/11 6:32 p.m.
.... Uh, you may be the first. :) I can't find nothing. Even the usual maniacs on the LS1 board haven't thought of this one.
Streetwiseguy Dork
8/31/11 7:53 p.m.
I haven't found one either. Got a customer who bought one, after being told the sound of the piston hitting the cylinder head was a lifter rattle...
Giant Purple Snorklewacker
8/31/11 8:32 p.m.
Well... there is no sense in having too little hood scoop now is there? If you have to have one - it should be huge. But, you know, tasteful...
Taiden
Taiden Dork
8/31/11 8:34 p.m.
That might be the best idea I've heard in a while.
corytate
corytate Reader
8/31/11 8:41 p.m.
as big as can be! 10" cowl induction hood!
noddaz
noddaz GRM+ Memberand New Reader
8/31/11 8:43 p.m.
Giant Purple Snorklewacker wrote: Well... there is no sense in having too little hood scoop now is there? If you have to have one - it should be huge. But, you know, tasteful...
I think I threw up a little because of that...
8/31/11 10:15 p.m.
well... as it is a drag car.. it might actually be functional
BoxheadTim
BoxheadTim GRM+ Memberand SuperDork
8/31/11 10:33 p.m.
Might be easier to find a replacement engine though (yeah, I know, spoilsport), given that it's usually the transmissions that give up on those.
Streetwiseguy Dork
8/31/11 10:49 p.m.
BoxheadTim wrote: Might be easier to find a replacement engine though (yeah, I know, spoilsport), given that it's usually the transmissions that give up on those.
Actually have found 2 donors with bad boxes. This is a ...nice?...SVX, so if a guy were a bit strange, it would be worth fixing. I think he's a bit miffed about the engine in his pristine new to him car blowing up, so the decision is being delayed.
Subaru sells a fresh shortblock for $2700. If its a keeper, that might be the way to go, cause then you could justify spending the $2k on the trans when it blows up next week.
DoctorBlade
DoctorBlade Dork
8/31/11 10:56 p.m.
There's the AWD thing too. You'd end up having to either spend cash on a good AWD setup or go RWD only. Glass transmissions don't help either.
EvanB
EvanB GRM+ Memberand SuperDork
8/31/11 11:16 p.m.
It just needs an LS1 + T56, RWD only and it will be perfect.
fasted58
fasted58 Dork
9/1/11 1:13 a.m.
your engine, shop or bank account are never too big... why not your hood scoop
logicfactory
logicfactory New Reader
9/1/11 8:50 a.m.
aerodynamics should not be taken lightly; adding some arbitrarily large hood scoop just leaves efficiency on the table so some other more logically conceived car can drag yours down the track and put it on the trailer.
corytate
corytate Reader
9/1/11 9:25 p.m.
set it so low in the bay that it almost drags the ground, and run stock hood.
9/1/11 9:46 p.m.
drysump?
tHiVkgfLlyE7D5JfxSjqcVumEtM0EtKQdLhlHXyto6JE6Wb2nP7W2VUQ8I4DjfGn
