Woody
Woody GRM+ Memberand MegaDork
10/1/15 10:25 p.m.
I know nothing about rotaries, but I might be going to look at one. The body seems solid, but I don't know what to look for when it come to determining if the engine is any good. I'm not looking for an engine swap candidate.
kb58
kb58 Dork
10/1/15 11:26 p.m.
If it starts. Seriously, if it's down on compression at all, that's the first thing that gets difficult. My brother and his rotary experiences taught me that.
Rufledt
Rufledt UltraDork
10/1/15 11:43 p.m.
If you do get it, then let me welcome you to the "Mazda's with vital, fragile, no longer available parts" club! That may be a bit of an exaggeration, there were LOTS of 12a's made so the engines are still out there, just limited now.
MrJoshua
MrJoshua UltimaDork
10/2/15 5:19 a.m.
If it doesn't currently run take a really good high capacity battery with you. Install the battery to try to start the car instead of trying to jump it.
Tyler H
Tyler H GRM+ Memberand SuperDork
10/2/15 7:53 a.m.
MrJoshua wrote: If it doesn't currently run take a really good high capacity battery with you. Install the battery to try to start the car instead of trying to jump it.
^This. Or a tow rope.
crxmike
crxmike Reader
10/2/15 8:23 a.m.
Lucky! When and where you looking at a rotary? Can I come? ;-)
Harvey
Harvey GRM+ Memberand Dork
10/2/15 8:42 a.m.
But it's burning oil!
Woody
10/2/15 8:56 a.m.
crxmike wrote: Lucky! When and where you looking at a rotary? Can I come? ;-)
Not sure if I even am yet. I don't even have a place to store the car for the winter.
Woody
10/2/15 9:24 a.m.
What parts are hard to get at this point?
Dave
Dave New Reader
10/2/15 9:32 a.m.
Woody wrote: I know nothing about rotaries, but I might be going to look at one. The body seems solid, but I don't know what to look for when it come to determining if the engine is any good. I'm not looking for an engine swap candidate.
More specifically hard hot starts are a good indicator of issues.
mazdeuce
mazdeuce PowerDork
10/2/15 9:39 a.m.
Woody wrote: What parts are hard to get at this point?
Rotors and housings.
Edit: OK, that's not really true, plenty of them out there, but when Mazda stopped officially supporting the engine full scale hoarding went into effect. Prices of pieces jumped to reflect this. Also the source of junkyard engines pretty much dried up. No longer can you just pop by the scrap yard and grab another motor and put it in for cheap.
Woody
10/2/15 9:47 a.m.
In reply to mazdeuce:
You've got some mail.
RX8driver
RX8driver New Reader
10/2/15 9:49 a.m.
For the housings, I recall reading that one could mill a little off both sides of a 13B housing and you get the benefit of a wider exhaust port, but I could be wrong. At that point though, why not just put a 13B in it instead?
Woody
10/2/15 9:52 a.m.
RX8driver wrote: For the housings, I recall reading that one could mill a little off both sides of a 13B housing and you get the benefit of a wider exhaust port, but I could be wrong. At that point though, why not just put a 13B in it instead?
Woody wrote: I'm not looking for an engine swap candidate.
Hungary Bill
Hungary Bill GRM+ Memberand SuperDork
10/2/15 9:54 a.m.
IF you did run into 12a parts supply issues, Racing Beat has a 12a to 13b engine mount adapter for about $120, there's also an intake adapter that allows you to retain the carburetor (a holley 350cfm available too).
In San Antonio a "13b" craigslist search would sometimes yield $50 engines that died and had been removed. I bought two such engines and made one good one with an Atkins rebuild kit. The added bonus being it gave me "rotary trophies" (usually with apex seal failures) to decorate my garage with
(atkins also lists a rebuild kit for the 12a)
Good luck!
Just in case you've never done a rotary engine compression check
Hungary Bill
10/2/15 9:55 a.m.
^ ah, beat me to it
BoxheadTim
BoxheadTim GRM+ Memberand UltimaDork
10/2/15 9:57 a.m.
13B isn't that much of a swap, if you put the right front iron onto the motor it's a drop in replacement.
As Dave said above, easy hot starts are a decent indicator of usable compression.
If you can get it started from cold, even if you can't drive, let it run until it's up to temperature, turn it off and try to restart it a couple of minutes later.
Also, I tend to have a good look at the engine while it's idling - if it's a stock rotary, it should idle so smooth that you can almost balance a thick coin on it. If you see any sideways movement, that would be an indicator of one face (well, usually two) on a rotor being a tad low.
Woody
10/2/15 10:56 a.m.
Woody
10/2/15 10:56 a.m.
mazdeuce
mazdeuce PowerDork
10/2/15 11:11 a.m.
That's really pretty. Knowing the job you did with the dirty 911, I think you could have a good time tinkering this one back to a really beautiful classic car.
wvumtnbkr
wvumtnbkr GRM+ Memberand SuperDork
10/2/15 11:12 a.m.
Check for smoke a little after startup. At startup it probably will smoke.
Check the coolant level before starting. Leave the cap off and start it. If it pushes water out very quickly it has an issue with the water seals.
MrJoshua
MrJoshua UltimaDork
10/2/15 11:20 a.m.
That is indeed a very pretty 7.
It always amuses me how much crap Mazda hangs off of their engines and how far away they put the accessories.
Wheres my engine?
Oh there it is:
JamesMcD
JamesMcD Dork
10/2/15 11:21 a.m.
wvumtnbkr wrote: Check for smoke a little after startup. At startup it probably will smoke. Check the coolant level before starting. Leave the cap off and start it. If it pushes water out very quickly it has an issue with the water seals.
...Or if there is a stream of bubbles coming up.
BoxheadTim
10/2/15 12:17 p.m.
Also, with this generation RX7, make sure that the choke is actually working properly. It's supposed to be pulled in as the engine warms up and that mechanism is often broken.
Nice looking car, and they're fun to drive.
Trackmouse
Trackmouse HalfDork
10/2/15 12:29 p.m.
Don't forget- with any rotary, ATF is your starting fluid. I got a clapped out series one LS SA to start numerous times by dumping atf down the carb.
dcXXRQ6h9odFUp6zfwV6jqEJeTLGwrclWw1dEngGU3IBPKhbokvOzpwF8YHLQlP3
