914Driver SuperDork
1/8/11 3:35 p.m.
Flat six, light body. Will you get rear ended on a 55 mph highway?
AngryCorvair
AngryCorvair GRM+ Memberand SuperDork
1/8/11 3:36 p.m.
it'll go faster on the back of a rollback, LOL. buy it anyway!
eastsidemav
eastsidemav Reader
1/8/11 3:47 p.m.
Probably. My father-in-law's 30 Chevy 6 cylinder is screaming at 45 MPH, but has a theoretical top speed of 55-60, I think. At that speed, the generator is also overcharging the battery - the end result was not good.
stuart in mn
stuart in mn SuperDork
1/8/11 4:03 p.m.
I would imagine one in good condition will go 55 on the highway, but it probably won't be very happy doing it for very long - per the site below they had a 4.33 rear axle ratio. On the plus side, they had hydraulic brakes so you may able to stop the car. ;)
http://www.ply33.com/
Rob_Mopar
Rob_Mopar HalfDork
1/8/11 4:07 p.m.
A guy I used to work with had a '34 Plymouth coupe. He said it would cruise comfortably at 45 all day long. I think his might have had an overdrive of some sort. He usually stuck to back roads when he was out and about in it.
Giant Purple Snorklewacker
1/8/11 4:21 p.m.
It will accelerate at 9.8 m/s^2 and if you drop it from high enough it will 200+ before terminal velocity.
1988RedT2
1988RedT2 HalfDork
1/8/11 8:18 p.m.
Giant Purple Snorklewacker wrote: It will accelerate at 9.8 m/s^2 and if you drop it from high enough it will 200+ before terminal velocity.
Yay, physics!
wheels777
wheels777 Dork
1/8/11 10:04 p.m.
I do know of a 1939 P8 that went a little over 100, but the flattey was still at the house
Appleseed SuperDork
1/10/11 12:28 p.m.
My buddy's 39 did 55+ but it was very, very unhappy about it.
914Driver SuperDork
1/10/11 12:38 p.m.
The '33 in question has larger diameter I-H wooden wheels out back, maybe more top end but less grunt off the line.
minimac
minimac SuperDork
1/10/11 12:54 p.m.
The better question would be "who has the cajones to drive it @55".
JAOnfClMpyNAqB3irGDZCtUH6Ucqa6NKRgZBuCL0iqF10KsZIWmX4OaOV62FCo20
