carbon
carbon Dork
12/20/14 8:26 p.m.
In an unheated dry garage on an engine stand before it needs to be freshened? Should I pull the head?
(The engine in question has metal matrix composite cylinder walls)
novaderrik
novaderrik PowerDork
12/20/14 8:26 p.m.
forever
carbon
carbon Dork
12/20/14 8:32 p.m.
So fire it up and throw 10psi at it?
novaderrik
12/20/14 9:12 p.m.
sure... why not? if everything checks out after initial startup, then run it like you stole it.
Kenny_McCormic
Kenny_McCormic PowerDork
12/20/14 9:39 p.m.
Properly prepared? Years. Decades in a climate controlled room.
Trans_Maro
Trans_Maro UberDork
12/20/14 10:59 p.m.
I've gotten them running after sitting outdoors for decades.
Indoors should be a walk in the park.
carbon
carbon Dork
12/21/14 12:20 a.m.
awesome
Streetwiseguy PowerDork
12/21/14 9:32 a.m.
Does it turn? If yes, fire it up.
AngryCorvair
AngryCorvair GRM+ Memberand UltimaDork
12/21/14 6:38 p.m.
yep, if it turns, prime the oil pump and throw some fuel and spark at it.
noddaz
noddaz GRM+ Memberand Dork
12/22/14 6:56 a.m.
Pull the plugs, shoot some oil in each cylinder. Crank over by hand. Prime oil pump if possible. Crank until it builds oil pressure. Drive.
jsquared
jsquared Reader
12/22/14 4:22 p.m.
^^This one. Building oil pressure before letting it spin on its own is key.
Kenny_McCormic
12/22/14 4:32 p.m.
Clarification, crank until it builds oil pressure with the plugs out. You can spin it up damn near dry in that situation and not hurt it.
Trans_Maro
Trans_Maro UberDork
12/22/14 7:45 p.m.
I just started a Continental straight 8 in 1926 Diana roadster today, after what was at least a 5-year slumber.
Used exactly the methods everyone has been posting.
She lit off without a hitch.
Your modern engine will be fine.
0o8d9VpaKzphrHmDzNNYbMQWAJY0Q7qOP6eWpvHw52aBa09mS5V4KsrNr9RhoMpC
