SPG123
SPG123 Reader
7/27/15 5:49 a.m.
We are parting out an 84 F150. The seller claimed that it had a 351 but we believe that it has a 302. How to tell the difference?
bentwrench
bentwrench HalfDork
7/27/15 6:26 a.m.
A 351 is taller, the distributor hole is ~1/2" below the intake gasket surface.
wclark
wclark Reader
7/27/15 6:42 a.m.
the 351W has a 1-3-7-2-6-5-4-8 firing order versus the 1-5-4-2-6-3-7-8 found in the 289/302.
Woody
Woody GRM+ Memberand MegaDork
7/27/15 6:56 a.m.
wclark wrote: the 351W has a 1-3-7-2-6-5-4-8 firing order versus the 1-5-4-2-6-3-7-8 found in the 289/302.
That firing order should be cast into the top of the intake manifold.
cwh
cwh PowerDork
7/27/15 8:13 a.m.
302 is much narrower, 18" across exhaust manifolds IIRC. Intake is much smaller than a 351.
NOHOME
NOHOME UberDork
7/27/15 8:27 a.m.
302 Block. Note distributor hole.
351 Block. Note sunken distributor hole.
edizzle89
edizzle89 HalfDork
7/27/15 9:30 a.m.
also, as seen above, the head deck height is higher up from where the water pump bolts up
Woody
7/27/15 9:33 a.m.
NOHOME wrote: 302 Block. Note distributor hole. 351 Block. Note sunken distributor hole.
Thanks, I've never noticed that before.
jimbbski
jimbbski Dork
7/27/15 9:35 a.m.
The firing order can vary based on what cam is in the engine so don't count on what is cast into the intake. If someone changed the cam... who knows?
NOHOME had it, look at the blocks, an easy determination using those pictures.
SkinnyG
SkinnyG Dork
7/27/15 9:40 a.m.
scottdownsouth
scottdownsouth Reader
7/27/15 11:14 a.m.
The water pump deck height is the easy way to tell. If the head is sitting on top of the water pump its a 302 or 289...or 260.
SPG123
SPG123 Reader
7/28/15 5:33 a.m.
Thank you very much. You folks rock!
9YjVfsCTFwlJGfzOtUjMX0hBKVQxZKnOug5d7pnBBXFpGw6IZfMeeOntIFE42beS
