I wonder if a throwout from a AX15-equipped Jeep would work.
I salvaged such a throwout bearing from the "new part but too old to send back for return credit" dumpster pile from a job I had 15 years ago. I have absolutely no idea where it is, but I know I have one. Want me to try to hunt it down to take measurements/pics?
If it is not too much trouble. These are mostly special order items at the stores here, so it's difficult to touch and feel different options.
My buddy had a stash of Ford stuff I was going to try but when I went over there he had cleaned up the wreckage.
Note - I am looking for an internal hydraulic TO assy that has a 35mm ID.
With no disc in the clutch I have 1 7/8" from the fingers to the shoulder on the snout.
Seems kinda short for a hydraulic release.
I may have to use a fork.
Too cold to go back out there and see how much the fingers move back with a disc in it.
Kenny_McCormic wrote: Check Summit, they sell universal ones in all sorts of sizes IIRC.
Thanks sadly, Nothing definitive. Trans has 1.380 / 35mm snout sleeve.
I have a 96 S10 that I just did a clutch job on. One thing I learned... It has a hydraulic clutch slave cylinder that pushes on the T/O bearing, which is its own part. And the slave cylinder bolts to the trans case.
