G_Body_Man
G_Body_Man SuperDork
3/22/17 7:52 p.m.
Update: It just got sunny out. Wow do these things ever look good in natural light.
The0retical
The0retical Dork
3/22/17 7:55 p.m.
I painted a computer case with that stuff back in my misspent youth.
My roommates thought I had finally lost it
Fitzauto
Fitzauto Dork
3/22/17 8:13 p.m.
I need this.
joey48442
joey48442 PowerDork
3/22/17 8:37 p.m.
Back in the 90s when I was in high school we had window tint like this
RealMiniParker
RealMiniParker UberDork
3/22/17 9:32 p.m.
I need this. Dunno what I'm gonna paint it on, but I need it.
ssswitch
ssswitch Dork
3/22/17 9:54 p.m.
I used Duplicolor Effex (which is a similar setup) on bronze metallic. It works best on a flat colour, metallic tends to wash it out except in extreme-angled sunlight. Very "rainbow trout."
Poor lighting, but here's what my Forester winter steelies looked like right after spraying:
I put about eight light coats on.
Was going to use Effex Black with Krylon Black on my Honda steelies this year, but any kind of clear sprayed on top seems to have made the Krylon immediately freak out and turn into The Blob so that's out. Not sure if Tremclad is better for being cleared over - this stuff is expensive so I might try prototyping it with just normal Duplicolor clear first.
Here's a picture of Effex on some guy's CAI (not mine):
rodknock
rodknock New Reader
3/22/17 9:55 p.m.
Oooh I need this in my life. Off to find something that needs paint.
RealMiniParker
3/22/17 10:59 p.m.
In reply to ssswitch:
I've found that nothing but more Krylon goes over Krylon.
G_Body_Man
3/22/17 11:03 p.m.
Krylon really is the worst. Effex only really sprays well over dark colors or candy coats.
Wxdude10
Wxdude10 Reader
3/22/17 11:07 p.m.
All this reminds me of
Sky_Render
Sky_Render SuperDork
3/23/17 7:33 a.m.
I need this. I have no flipping clue what I'm going to paint with it, but I need it.
NickD SuperDork
3/23/17 7:47 a.m.
I saw a Maverick painted black with this clearcoat all over it. The appearance was questionable. The nitrous'd, tunnel-rammed small block with a 4-speed and slicks was not.
Cotton
Cotton UberDork
3/23/17 9:58 a.m.
That playing card idea is excellent for "taping off" the tire.
3/23/17 10:40 a.m.
It's gotta be better than gallons of Axe body spray.
chandlerGTi
chandlerGTi UberDork
3/23/17 10:54 a.m.
Cotton wrote: In reply to ssswitch: That playing card idea is excellent for "taping off" the tire.
And re-useable!
That Jetta Was actually House of Kolor and was a stupid expensive paint job but it was a little obnoxious for a non-lowrider.
ssswitch
ssswitch Dork
3/23/17 11:27 a.m.
It worked pretty well but I ended up having globs where wet paint was dripping down the cards and sealing against the bead. A lot of the rim of the wheel was not coated well.
3.5" index cards is what I use now, they work better (easier to 'mould' to ensure even coverage), absorb any wet overspray better and are cheaper.
Still in search of a good solution for taping off the valve stem.
QuasiMofo
QuasiMofo MegaDork
3/23/17 11:39 a.m.
In reply to Huckleberry:
Have you been looking at the ZtwennyHATE build plans already?
G_Body_Man
3/23/17 11:40 a.m.
Cut the pinky finger off of a small rubber glove. That should be about perfect for most valve stems.
Trackmouse
Trackmouse SuperDork
3/23/17 3:36 p.m.
It worked pretty well but I ended up having globs where wet paint was dripping down the cards and sealing against the bead. A lot of the rim of the wheel was not coated well. 3.5" index cards is what I use now, they work better (easier to 'mould' to ensure even coverage), absorb any wet overspray better and are cheaper. Still in search of a good solution for taping off the valve stem.
Use a large straw. Like for drinking bubble tea. Slides right over.
RXQhODTZDlrHhfBv2QJ1OtTCSWfoctR618X2Nqo5cWryTqBzmKQhVnRFn1COYsdJ
