Wally (Forum Supporter) said:In reply to Steve_Jones :
It's definitely not a 4 hour full charge. Ours was delivered on 8 percent and we left it plugged in for about 30 hours to get it up into the 90s. After that it's stayed charged up enough to live with but coming up from nothing is a long process.
You mis read, not 4 hour charge, 4 miles per hour plugged in. Need 40 miles? 10 hours, etc.
I did, ours did a little better but certainly not overnight for a full charge off a 110 outlet.
True. It isn't designed to do that. It's design is a top up charge.
frenchyd said:Wally (Forum Supporter) said:In reply to Steve_Jones :
It is designed to charge. Charging is a function of power input. Power is voltage times current. It's that simple.
Steve_Jones said:frenchyd said:Wally (Forum Supporter) said:In reply to frenchyd :
We have a Bolt at work but haven't gotten a charger installed for it yet. Charging on 110 has been very slow, it would not be practical as someone's only car.
The new bolt has 200? Mile range?
Average daily commute is 35 miles.
So for the average person who plugs in every night it will be fully charged.
And even if it's 50-70 miles it will still have range left at the end of the week.
The 80-20 rule is what people need to learn. Charge it to 80% and drive it to 20%That's when chargers work the fastest.
I don't know the deal GM and ford have to allow them to use the Tesla superchargers, ( by the way it's now Tesla Ford GM Volvo Mercedes Rivian, Lucian, VW (?) SAE )But instead of sitting at chargers for hours now they will recharge in 15 minutes or so. About the time it takes to go to the bathroom and grab a hotdog.
Try again. GM says 4 miles per hour on 110. You say fully charged overnight, GM says your 200 mile charge would take 50 hours. How long are nights in MN?
Please go back and carefully reread what I said.
The average American drives 35 miles per day. If you come home and plug in. It will have a full "tank". By morning.
If you drive 50-70 miles per day and do the same thing. You will still have charge left at the end of the week.
Not that I would *necessarily* recommend it, but I dailyed my Model 3 only charging on 110v for 2-3 weeks. Honestly with knowing what I know now, the real limitation in doing that is the batteries internal BMS won't be able to stay at a low state of charge to "learn" it's capacity (since you'll come home and toss it onto the charger right away) so it'll falsely report your total battery capacity as decreasing when it isn't, all due to how it averages the pack mathematically.
I thought it was doing that to me so I did an experiment once I learned how the pack averages- I spent a week where, instead of recharging the car every night I alternated, and would leave the car for long stretches at certain points so the BMS could long-term balance and "learn" it's average. I also specifically drained it down to ~30% and left it there for about 4 hours before allowing it to recharge; end result after one whole week of doing that, was I "regained" over 10 miles of total range. Now on workdays I don't charge each night so the BMS "learns" more averages
You are the second person who has said that. I guess I still have a lot to learn about charging.
Sandy Munro says to only charge to 80% unless you are leaving immediately and you shouldn't go over 90% even then in order to have some regeneration room. Charge it back up before it's below 20%.
Wally (Forum Supporter) said:frenchyd said:AnthonyGS (Forum Supporter) said:Indy - Guy said:frenchyd said:......
..... Some countries Tesla's are 70% of new car sales but in many nations Tesla #1 new car sold.
Name one country that Tesla is 70% of new car sales.
If you can dodge a wrench, you can dodge any question.... dodge, dip, duck, dive..... dodge, dip, duck, dive
Norway
No, just no.
80% of new cars sold in Norway were electric. 12% of those were Teslas.
https://www.cbsnews.com/amp/news/electric-vehicle-europe-norway-tesla-sales/
Wally, facts are irrelevant in this train wreck.
(come on 100!)
frenchyd said:Steve_Jones said:frenchyd said:Wally (Forum Supporter) said:In reply to frenchyd :
I did reread it, I'll paste it here:
Chevy's bolt is one that plugs into 110 volt outlet and draws Only 20 amps.
With a 40 mile commute you can start charging after you go to bed and have a full "tank" by morning.
You said "after bed" and are now changing it to "come home" but let's stick with that anyway. 50-70 miles (your words) will take 12.5 to 17.5 hours according to the people that make and sell the car so if I plug it in at 6 and need 70 miles "morning" is 11:30...
If I work 8 hours, and commute 30 mins each way, I only need 26.5 hours in a day to make it all happen. Who do I talk to to get 26 vs 24 hours in a day?
You are right. I stand corrected.
The neighbor with one says it's ready in the morning.
Oh by the way I was also wrong, the Bolt has a 238 mile range not a 200.
But I don't know how that works with the 80-20 rule. Reportedly for maximum battery life you shouldn't charge it to 100% or run it below 20%.
I did find nd out what the issues are with the GM batteries ( at least according to the web. GM's batteries are called wet layup while a lot of batteries are dry assembly. . I heard Elon Musk explain the difference.
Since Tesla fires are rare and GM/ Ford fires are more common it seems there is some validity to that?
Note; I am far from a battery expert. And frankly with the multiplicity of battery chemistry. Pretty unlikely to ever be an expert.
But there are batteries that can be charged in 5 minutes ( Borophene) and batteries that will last 100 years or more ( CatbonCarbon ) And Manganese Iron Ion
Sodium Ion. Solid state. Etc.
It's the BMS, not the battery. The management systems work to equalize through using resistors to bleed off charge on the cells to equalize them to hundreths of a volt each- they work by essentially wasting electricity to equalize all the cells. Tesla wanted the battery to be as efficient as possible, so they went with as few of these resistors as possible (the fan groups say there's only 4, one for each cell pack) so not only do they take a long time to balance but they also can't balance if the car's battery is still actively being used. Keep the computer from going into a deep sleep and test like that and it can't accurately plot your battery average, power density or balance- it's process that only takes ~3-4 hours but can't happen if you're trying to charge it at the same time or use power-hungry things like sentry mode. It just means you should infrequently leave it at a drained state for awhile so the computer can say "when each cell is at 3.1 volts I'm at 15% charge" or whatever, and be sure of it.
No computer ever 100% knows how much power is in a lithium battery; they only really "know" based on lots of math and practical experience, temperature, how many amps it could store new, internal resistance, and to have all that information graphed. This is partially due to the same thing that makes them so usable for EVs- their voltage remains consistent as they're discharged. Regen "Room" is literal, that percentage is to give room for the batteries to take power.
Keeping charge around 80% is because the pressure of the stored chemical energy will literally make the battery expand- it'll separate the jelly roll that carries the electrons from the layers, which is why they degrade and eventually puff up. Charging only to 80% instead of 100 all the time increases lifespan logarithmically, it's like for every 0.1 volt UNDER the 4.2v maximum you charge a battery cell you more than double it's lifespan. If you use a battery only 40-60% of it's capacity- which Toyota does for the older NiMH Prius batteries- you'll get decades of life.
Steve_Jones said:If I work 8 hours, and commute 30 mins each way, I only need 26.5 hours in a day to make it all happen. Who do I talk to to get 26 vs 24 hours in a day?
Do you remember the Futurama episode, where to solve global warming they pushed the Earth away from the sun ?
In reply to GIRTHQUAKE :
Don't laugh too hard at that episode. The current administration is talking about the possibility of blocking the Sun to cool down Earth.
Sandy Munro says to only charge to 80% unless you are leaving immediately and you shouldn't go over 90% even then in order to have some regeneration room. Charge it back up before it's below 20%.It's the BMS, not the battery. The management systems work to equalize through using resistors to bleed off charge on the cells to equalize them to hundreths of a volt each- they work by essentially wasting electricity to equalize all the cells. Tesla wanted the battery to be as efficient as possible, so they went with as few of these resistors as possible (the fan groups say there's only 4, one for each cell pack) so not only do they take a long time to balance but they also can't balance if the car's battery is still actively being used. Keep the computer from going into a deep sleep and test like that and it can't accurately plot your battery average, power density or balance- it's process that only takes ~3-4 hours but can't happen if you're trying to charge it at the same time or use power-hungry things like sentry mode. It just means you should infrequently leave it at a drained state for awhile so the computer can say "when each cell is at 3.1 volts I'm at 15% charge" or whatever, and be sure of it.
Thanks for taking the time to explain it to me. I really appreciate that.
The Tesla with a million miles only used 2 batteries and the current one still has life in it.
I had assumed that to get that many miles in that short of time it was in use 24/7/365
But apparently not ?
racerfink said:In reply to GIRTHQUAKE :
Is that by blocking the sun with solar panels?
Oh that Tesloop taxi service in Cali? I think that one was supercharging twice a day with an overnight rest period.
All Teslas have a 12v battery- used to be lead-acids, now small lithium iron phosphates- to run the computer systems in a "low power" state; that way if the car spends a long period without power and discharges the battery pack past a safe point, you can activate ONLY that computer which will allow it to run diagnostics and trickle-charge the main pack to test. It's an old government mandate they turned into a safety mechanism.
In reply to racerfink :
Thankfully they're also making the biggest action on climate change yet; I don't doubt they've got someone researching that tier of engineering, but we already do similar with Jet exhaust from planes (just not intentionally).
OHSCrifle said:racerfink said:In reply to GIRTHQUAKE :
No, pumping materials into the atmosphere to reflect sunlight. We actually do this already through jet engine exhaust; the ice clouds of the condensation reflects light but the CO2 exhaust also keeps stuff in, and because it's in high atmo there's no plant life to respirate it.
I can't remember where, but I DO remember there was a study ran that needed all flights across America to stop in order to check, and they got that moment after 9/11. I can't remember what they found, but now I might spend some time to find that study again which showed how crazy of an environmental change no flights made.
This post has received too many downvotes to be displayed.
Steve_Jones said:frenchyd said:Steve_Jones said:frenchyd said:Wally (Forum Supporter) said:In reply to frenchyd :
If you drive 50-70 miles per day and do the same thing. You will still have charge left at the end of the week.I did reread it, I'll paste it here:
With a 40 mile commute you can start charging after you go to bed and have a full "tank" by morning.You said "after bed" and are now changing it to "come home" but let's stick with that anyway. 50-70 miles (your words) will take 12.5 to 17.5 hours according to the people that make and sell the car so if I plug it in at 6 and need 70 miles "morning" is 11:30...
I see where I was wrong.
You say you drive 30 minutes each way? The neighbor who works at Toro is 34 minutes away and that's only 17 miles 1 way. So 34 miles round trip.
( I assumed it was 50-70 miles away).
That's how he does it.
30 minutes? How many miles? Remember if in rush hour traffic when you slow down you regenerate power back into the battery.
Let's assume you are doing 60 mph as soon as you open your garage door.
That's 30 miles. Or 60 round trip.
using your math, plug in at 6:30 pm and unplug at 8:30 am. 14 hours times 4 hours 56 miles so Monday you start out with 238 miles. And Tuesday you have 234 miles. Wednesday you have 230 miles Thursday you have 226 miles Friday you are down to 222 miles of range.
Shopping and church ? How many miles?
A more middle of the road car, the Tesla model Y. Is going to have 340 miles range ( the new model with the 3680 batteries).
Since you don't have 220 volts in your house? I'll have to figure out what the charge time.
Or I can estimate the model 2 for you ($25,000) on 110 volt.
But that isn't due until 3/4 2024 and typically it takes a wile for Tesla to catch up with the pre- orders.
Unlike Chevy you don't go to the dealer to buy. You go on line and order it. $100 deposit required.
So no salesman is going to pressure you.
You can move the goalposts all you like, I used your numbers to prove you wrong, changing them now does not magically make that go away.
As far as my specific situation, I do not have a 30 min commute, again, I was using your examples. I do not have a 220 charger at my house, I do have one at my warehouse, because as stated before, we have electric vehicles. I'm not worried about any salesperson pressuring me as I've purchased over 200 cars, and currently own over 20, so pretty sure I know how to do it. You like to assume everyone has the same situation and the Tesla is the perfect vehicle for every situation for some reason. It's not. If it works for you, great! Go buy one.
Recent posts got me thinking, so I did a bit of checking. EV range doesn't appear to work out the same way as we typically associate ICE range. With a typical ICE car, you take it's highway MPG rating and multiply it by the size of the gas tank. So if your car gets 30mpg highway and has a 15 gallon tank, we say it has a range of 450 miles- depending on how comfortable you are running your tank low and how close your driving is to the MPG rating. Most people in the above scenario would be fine with calling it 425 miles.
With the vast majority of EV's, they get their best range to lower speeds, and range can drop substantially at highway speeds. Add to that the general rules of avoiding charging past 90%, and below 20%.
Here is an example.
According to this Car and Driver article on EV range…
The Chevy Bolt we have been talking about drops from it's rated range of 238 miles to just 180 miles of highway driving. That sounds like a substantial difference, and that is at 100% charge. Following the 90%/20% recommendations, that would drop to just 126 miles of highway driving. Though one would assume that rule would be ignored on a "long" trip. Is this accurate, or is C/D off the mark?
Steve_Jones said:In reply to frenchyd :
Steve;
I said you were right.
Then I realized I was wrong again about range.
Finally I explained why I was wrong again.
I did not change the numbers. I attempted to show you how it would work.
As far as dealing with salesmen. As a life long professional who made a nice living. I really hate working with those who have no idea of how to sell.
If you enjoy that interaction then you and I are just different. That doesn't make either one wrong.
As far as trying to sell you anything, what do I gain?
I'm. A gear head. I'll keep working on my V12's all the rest of my life. They are fun toys.
As for boring transportation? I'm just looking for the most cost effective way to meet those needs.
While it probably won't happen in my lifetime, the idea of crawling into the back seat, going to sleep and arriving someplace rested is extremely attractive to me.
In reply to Boost_Crazy :
I'm not sure; I can only give my experiences with my Model 3, which I bought used over 100,000 miles and with a range of about ~240 miles on a full charge. It seems to be dead-on regardless of how I drive, except for the times I'd drive on the interstate like a moron repeatedly doing pulls and going over 80. For the record I typically cruise at 70-75 and I do interstate for 3/4ths my work commute.
Wind resistance increases logarithmically past 35mph and the EPA rating is based on mixed use and not constant interstate/highway, so doing 75mph for hours like that in a test doesn't seem off the mark- but for our Bolt example we'd need an owner to know, and the one I know might be at work tomorrow. I know it's asking a lot, but I wonder if they redid some of the cars at 60MPH what the alteration would be.
Boost_Crazy said:Recent posts got me thinking, so I did a bit of checking. EV range doesn't appear to work out the same way as we typically associate ICE range. With a typical ICE car, you take it's highway MPG rating and multiply it by the size of the gas tank. So if your car gets 30mpg highway and has a 15 gallon tank, we say it has a range of 450 miles- depending on how comfortable you are running your tank low and how close your driving is to the MPG rating. Most people in the above scenario would be fine with calling it 425 miles.
Here is an example.
You have an interesting point. But I think the whole focus on range is silly.
EV's are fast. When did going on long trips become the standard we measured cars by?
A 426 Hemi Cuda isn't a long trip car, is it?
Range anxiety is caused by the idea of sitting someplace for an Hour or more to go further. And what if I run out.
If you tend to run your cars out of gas? It will also happen with an EV.
Otherwise not. I can reach Chicago in about the same time in a Tesla as you can in that Hemi Cuda. < 300 miles from home. I'll pull into a supercharger and spend 15 minutes. empty my bladder and grab a hot dog.
You'll spend $190 bucks on gas. And make 2 stops.
If you are running the cannonball run across country time at a charger will cause you to lose. ( extremely small subset of people).
Really travel by car long distance has been replaced with airplanes.
it's an hour flight to Chicago and an 8 hour drive. Last I looked it's $99 one way. And it will cost you about that to drive just for gas. ( and tolls)
But Yeh! Towing the garage ? Use an ICE.
Most people drive from home to work and back. An EV will do that cheaper than ICE.
If you don't care about money? OK. Fair enough.
And I can buy a used Honda Fit for $7000 that will get 40mpg.
From a strictly cost standpoint an EV is not more cost effective in any way shape or form.
I get all the folks who like not having to stop at a gas station.
This topic is locked. No further posts are being accepted.
